Rusty4242
bought a splitter blade from northern tool and they want me to use a low hydrogen rod to weld it onto the splitter beam with. why won't 6011's do? thanks, Larry
My experience is that I get better welds with 6011 rods stored at 50%H than at 5%. Perhaps you know the reason for this.allengentry said:6011 DOES NOT require moisture to "function properly". That is absolutely false.
[SNIP]
ABSOLUTELY use 7018.
60XX will result in hydrogen being introduced into the base metal and weld, and will subsequently crack and break.
Allen
I will add, as allengentry said, ABSOLUTELY use 7018 and do at least 3 passes (assuming the blade is approximately 1 inch thick), let it cool some after each set of passes, you need pretty high heat. The 7018 welds will actually give to a bending force and act like spring steel, one could weld a leaf spring with this rod.allengentry said:6011 DOES NOT require moisture to "function properly". That is absolutely false.
"Moisture" in the weld puddle? Water vaporizes at 212*F, and the puddle is 3000* plus.....
6011 is MORE TOLERANT of moisture, and should be reconditioned if exposed to more than 70% humidity.
7018 is less tolerant of moisture due to the iron content/flux chemistry. It needs to be stored between 250-350*F 24/7.
Moisture content/contamination of the flux has zero impact in the amount of hydrogen introduced into the base metal. The flux/filler metal chemistry determines that.
The splitter blade absolutely has more carbon than A36, and likely is heat treated as well.
If you want to weld this properly, preheat both your splitter blade and base material you are welding to. In order to give you a proper pre-heat, I need to know the thickness of the base material.
And ABSOLUTELY use 7018.
Allen
SPYDERLK said:My experience is that I get better welds with 6011 rods stored at 50%H than at 5%. Perhaps you know the reason for this.
How does a dry 6011 introduce hydrogen? Is hydrogen inherent in the rod coating independent of water?
Magnesium ribbon can burn underwater by decomposing water. It seems to me that an electric arc is hot enuf to do this as well, thereby freeing hydrogen from a moist coating......??
larry
Hmmmm!allengentry said:I give you guys credit, you understand way more than most boards, which is good.
