#21 (permalink) | |||
Quote:
![]() Its on the inside, so nobody sees it once in use... ![]() Quote:
quality. My old digicam can take small movies, but dont expect too much of it when i try.. ![]() Quote:
No time for buggies now though, i have new brakes for the 5245 on shelf for about a year, but havent got time to install them yet.
__________________
By talking long enough without actually saying anything, anyone can become a prophet ![]() __________________ 1967 Zetor 3011, rebuilt trans, now needs mudguards 1986 Zetor 5245, my old man's tractor, i just own the loader 1996 Volvo 850 TDI 2007 Volvo 440 1.9 TD based dirt buggy, under construction Got tired of WinBlows XP, running Ubuntu Linux from now on !! |
#22 (permalink) |
Location: Boston & Martha's Vineyard, People's Republik of Massachusetts
very impressive Renze!
My family is from outside Arnhem - (velp) (the ones who stayed) - where is the Steernbos?
__________________
---------------------------------------- Charles Kubota B3030 Kubota M59 w/hydro thumb Neat stuff - ATI Preseeder, Hydraulic PHD, Wallenstein BX62r Chipper, Millonzi Grapple, CA 4n1 Bucket. Delta Hook Rear QA system. Too many other random attachments to list (or to own, per my gf) and a really bad tool addiction. But at least I haven't bought a dump truck or bulldozer. Yet. |
#23 (permalink) | |
Quote:
__________________
#24 (permalink) |
got the frame painted this morning:
first sprayed some "right over rust" Hammerite primer over the longitudinal frame tubes, because these were quite rusty. (i cleaned the most of it with a wire brush already, "right over rust" i take it for what its worth )Then i sprayed it all again with black Hammerite. Its about 27 euro for a 0.75 liter can, but it promises to hold better on rusty surfaces. I didnt want to use the cheap black varnish, because i am afraid it will remain sticky in the sun... dont know about its surface appearance either. Because of the poor light in the workshop, i'm not 100% sure of the paint coverage, but i just need to get things done now, or my summer holiday will be over without having a day off ![]()
__________________
#25 (permalink) |
from what I can see in the pictures, the sweeper is looking real good ! Anxious to see it all together and Working
Thanks for posting .bob
__________________
Kubota 4610, Kubota 4200, FEL's, JD 455, Toro Zero turn mower, Case 135 excavator, hydraulic dump trailer, york rake, disc harrow, land plow, bush hog, pallet forks, 3 pth seed spreader, 3 pth york broom, and other impliments of distruction.
#26 (permalink) |
got something visible today:
We assembled all parts, so the machine could be set outside, in the sun for the paint to cure and harden. I didnt tighten the bolts yet, it has to wait till the paint is tough enough.
__________________
#27 (permalink) |
Renze
That machine looks better than factory made !! Good job. Is the chain and clevis going to be heavy enough to handle the top link load ??? Bob
__________________
#28 (permalink) |
bob,
normal toplinks suffer most from compression forces, making them kink (i did that quite often before i had a front loader, using the 3pt hitch bucket to dig holes so deep that they could bury the tractor ![]() A chain doesnt take up any compression forces, so i think this chain will be ok. Regarding the force (500 kg ?) and the arm, i expect a max. static load of 1000 kg on the chain: Chains for lifting (not towing) allways are rated with a safety factor of 4, which means that if they are rated for 1 ton workload, they can handle 4 ton before they break. I cant find exact specs on the chain, but chains that are close, are rated 3 to 4 ton... So i'm not too worried about that.
__________________
#29 (permalink) | |
Quote:
Those casters are super heavy duty! nothing like the Harbor Freight crap we get around here. How is it you guys in Holland always get the good stuff I still have one concern though - your camera! It must be from Harbor Freight because it takes such crappy pictures . Your road sweep project come out great and deserves better. Nice work Renze, it's super heavy duty OK now, how much to ship it over here to me?Larry
__________________
I am a bomb technician, If you see me running try to keep up! |
#30 (permalink) |
Larry, this company also sells cheap stuff like Harbor Freight, but when i called them, i just got what i asked for, and payd what i asked for
97,50 Euro per caster, thats WITH 50% rebate which i get when buying via my employer ![]() It costs something, but then you've got something ![]() Other Dutch manufacturers ask about 2800 euro, for a machine with half the steel in it... (no frame, the sweep cover acts as frame) I think if i'd sell them commercially, i should ask 3500 Euro at least.. I'm glad i bought this 3011 as a chores tractor, because my brothers 2011 wouldnt be able to lift it anymore ![]() Sweeping close to barns, is a pain with the superwide cab with mirrors, on the 5245. My crappy camera is a Nokia 3110 with a broken dust glass: so all dirt gets to the lens. I think the paint is hardened enough to use it to clean the pavement before the weekend... I'll take my HP digicam and see if i can get some better photos and perhaps a little video...
__________________
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
