Rusty4242
Thanks to all the help I got on these forums, I have finally finished building my log splitter. Attached are some photos of it. After renting one a couple of times, I decided to build one with an electric motor to keep the fumes and noise down, which it does well, tho the 16 gpm haldex pump whines like crazy.I guess this was drowned out by the gas engine noise on the rentals. I used all the scrap steel I had been gathering for years. Knew it would come in handy one day. I bought a 12 inch splitter wedge, valve, filters and pump from Northern. Now I see that didn't need to buy a wedge. Would have been easy to make. I got a 3 hp , single phase, 220 volt electric motor on fleabay for 100 bucks. Apparently one electric hp is roughly equal to 2 1/2, 4 stroke hp . I got a 5 inch by 24 inch cylinder off a piece of heavy equipment. $50. Its cycle time is about 5 seconds for a full stroke, tho it rarely needs a full stroke to do the splitting, except on real knarley billits. I run it in the yard with about 30 feet of 12/3 romex. The 2 stage pump can really work. I put a removable wheel barrow wheel on one end to help be moved it around. The only problem I have is with some(cavitation?) noise from the pump after a couple of hours of heavy splitting when the oil temp (dextron 3 ATF) get up to about 125 degrees. f.. Anyone know about this? Thanks, Larry
