Wombat125
Gold Member
I know there have been zillions of bucket hook posts, but this is my first post in the Build-It Yourself forum, so please just indulge me with this.
I have the JD light-duty bucket on a 522 loader. I measured the main bucket chassis at only about .16" thick so I figured the 1/4" pads were mandatory.
There was a previous post where the builder only removed the paint where the weld was applied instead of completely under the pad. He ended up having to grind the hooks off, grind the rest of the paint off, and then re-weld the hooks. I took that bit of wisdom from him -- Thanks again TBN!!
Factory John Deere paint is good stuff. I use a very aggressive wire wheel cup attached to a 4.5" angle grinder. Most paint doesn't stand a chance with this setup, but the bucket took a lot of work to get the the paint off.
The pad to bucket welds are a bit discontiguous. That is because I welded them on in six sections with some cooling time in between to prevent warpage. I learned that lesson a few years ago welding on my Samurai.
Anyway, I might be buying a set of Toyota pickup axles to put under my Samurai. If this works out, the hooks will be employed lifting axles off the trailer.
