Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    New Member
    Join Date
    Aug 2008
    Posts
    3
    Default harrow drag
    New to the site and already have a question.What do yall think would be the best drag for a harrow that is to be used in the woods to plant food plots. Board or a steel pipe or any other good ideas. My problem is that we are getting a deep furrow from the outside disk on the back gangs.I tried less angle on the rear gangs but it didnt seem to help.Any ideas appreciated.
  2. #2
    New Member
    Join Date
    Jul 2008
    Posts
    22
    East Texas
    Default Re: harrow drag
    Two part answer. I don't know what kind of disk you have, but many disks, especially offsets, leave a furrow. Some manufacturers offer a "furrow filler" option to fill it in. You may want to check to see if you could add something similar to your disk. As to the type of drag, it depends on your dirt -- how big and hard the clods are, etc. I have used 2x8s, old fence, commercially made farm harrows and railroad rails. On the latter, I have one that consists of one rail about 8ft. I have another consisting of 3 rails chained together and spaced about 3-4 ft. apart. I think you will find conditions will vary and that changes what you need.
  3. #3
    Silver Member zionview's Avatar
    Join Date
    Nov 2007
    Posts
    232
    Central PA
    BX2200 and B8200HST Kubotas
    We built a drag out of 2X12s, overlapping them 2 1/2 to 3 inches to make a herringbone. It worked well in all the types of soil we had, and never dragged much ground if it dug in. In fact, we would occasoinally throw stones on it as we picked them to get it to smooth off the ground a little better. It was cheap and effective.
  4. #4
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,409
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    Quote Originally Posted by ccga View Post
    Used tires and a piece of telephone pole
  5. #5
    Elite Member
    Join Date
    Apr 2005
    Posts
    4,028
    nicholson, pa
    John Deer 318
    we used to drag a chain link fence with 4x4's bolted to the ends. I did find a nice old
    David Bradley attachment that has spikes and is addjustable. its great for stone and woods and i use it all the time now.
    forgeblast
  6. #6
    Veteran Member kthompson's Avatar
    Join Date
    Sep 2008
    Posts
    2,113
    South Carolina
    Kubota M 6800; Kubota B 2710; Gator; Bushhog ZTR; Volvo Mini Excavator EC45, Ferris ZTR and John Deere 5525 tractor
    If you use a drag it will have to extend past your disk and with you are in the woods, you will end up bending or breaking it most likely. The simplest solution might be to change the outside disk blades. I think the rule of thumb is the front outside blade is one size smaller and on the back gang two sizes smaller. If your disk is not level or twisted may not work.
  7. #7
    Super Member
    Join Date
    Sep 2000
    Posts
    6,596
    How about an I-beam attached to the draw bar by 20' of chain? You can make 2 attachment points. One with the beam in an "H" configuration to cut and fill and one in the "I" configuration to smooth.
    Or get 2 of them with the first in "H" and the second in "I" for a 1 pass finish.
    jb
  8. #8
    Member
    Join Date
    Dec 2004
    Posts
    44
    Aiken County South Carolina
    John Deere 790
    Last spring I prepared the ground and planted about 3.5 acres of bermuda grass. After discing I used 2 land scape timbers and some chain link fence as a drag. I pulled this rig with my 4 wheeler. It was much more manuverable than the tractor which would be a plus for you if clear space is limited around your food plots.
  9. #9
    Gold Member actionaj's Avatar
    Join Date
    Oct 2007
    Posts
    427
    Southern Illinois
    BX2350
    I use chain link fence too with landscape timbers for wieght. Just roll it up when your done for easy storage.
    BX2350
    FEL, RCK54 MMM, 4' Farm Star BB, 5' Farm Star RB, 5' Rake
  10. #10
    New Member
    Join Date
    May 2004
    Posts
    14
    StL Co/Macon Co, Mo.
    JD1070 MFWD
    Picked this one up at an auction for $4.00. Note the modifciation to add a 2" ball receiver.
    Attached Thumbnails Attached Thumbnails harrow drag-img_0974_1-jpg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
