HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-03-2008, 04:25 PM   #1 (permalink)
Member
Default chain top link
i have 3ft of heavy chain and plan to use to make top link do i have enough .and wondering about what to use for the end. any ideas welcome
beaner68 is offline   Reply With Quote
Old 09-03-2008, 05:09 PM   #2 (permalink)
Default Re: chain top link
I have used the larger open end style hook with safety catch. Easy on a off and they will stay put. You don't need to buy grade 70.
Tractor Supply Company - Grade 70 Clevis Slip Hook with Latch, 3/8 in
radman1 is offline   Reply With Quote
Old 09-03-2008, 05:15 PM   #3 (permalink)
These will also work but make sure your pin will fit through them.
Tractor Supply Company - Lap Link, 3⁄8 in.
Don't use these. They will pull apart.
Tractor Supply Company - Quick Link, 3⁄8 in.
Old 09-03-2008, 05:31 PM   #4 (permalink)
New Member
I determined the length by hooking up my brush hog to the lower arms and with the cutter sitting on the ground measured between the connector pin on the tractor and the pin on the cutter. I allowed for wrapping around both pins and hooking back into itself at both ends. Also, I allowed for a little extra for good measure. This works great on uneven ground while you're brush hogging.
jayste is offline   Reply With Quote
Old 09-03-2008, 05:39 PM   #5 (permalink)
Member
got the chain at TSC 2.12ft today was planning to use one end from a old top link .was wondering what would be best to use for other end ?
Old 09-03-2008, 08:13 PM   #6 (permalink)
Gold Member
How about a clevis?
Tractor Supply Company - Utility Clevis, 7⁄16 in. x 1-1⁄2 in.
Run the clevis pin thru the chain link and the top link pin thru the "U".
__________________
2006 Kama 554, 92 Belarus 250AS, Bombardier Outlander Max 400.
Brad_Blazer is offline   Reply With Quote
Old 09-04-2008, 06:44 AM   #7 (permalink)
Super Member
3RRL's Avatar
What will you be using the chain top link for...what implements?
__________________
Rob-
...The Older I get...the Better I Used to be...
3RRL is offline   Reply With Quote
Old 09-06-2008, 01:03 AM   #8 (permalink)
Member
i plan on using the top link on my brush hog only
Old 09-07-2008, 09:31 AM   #9 (permalink)
Quote:
Check out TSC's (SpeeCO) #0265113 stabilizer.
KevPH1 is offline   Reply With Quote
Old 09-07-2008, 09:53 AM   #10 (permalink)
Member
As a safer alternative, try running the chain through a length of pipe that is a bit shorter than your chain. This will provide a limiter to how much the implement (or tractor) can flip up if you snag something.
John861 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
