Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Silver Member Sherweld's Avatar
    Join Date
    May 2008
    Posts
    174
    Allyn, WA
    Kubota B7100
    Default Quick and dirty Wheel Handler
    This may be old news for some of you long timers, but I came up with a pretty good way of handling my rear tires which weigh some 120 pounds dry. Additionally the wheel on the end of the arm removes easily to handle wheel weights via a center hole.
    The scissor jack seems a bit handier than a hydraulic jack for tweaking up and down for the last small adjustments. The wheel on the end of the arm allows a surprising amount of "adjustment" to get the tractor tire in final position.
    I know I'm getting to be kind of a wimp, but at my age I think I deserve some pampering.
    Attached Thumbnails Attached Thumbnails Quick and dirty Wheel Handler-wheel-handler-jpg
  2. #2
    Member
    Join Date
    Aug 2008
    Posts
    45
    winslow arkansas
    farmtrac 300 dtc
    Default Re: Quick and dirty Wheel Handler
    now that looks real handy.your not a wimp your just working smarter
    farmtrac 300dtc fel 6ft finish mower,6ft brush hog,6ft rock rake,6ft box blade,4ft scraper blade
  3. #3
    Elite Member czechsonofagun's Avatar
    Join Date
    Jun 2006
    Posts
    3,404
    Old Dominion
    Kubota B1750
    I like it! Pretty ingenious.
    Regards,
    Prokop
    I was put on Earth to accomplish a certain number of things. Now I'm so far behind, I'll never die!
  4. #4
    Platinum Member curly's Avatar
    Join Date
    Aug 2007
    Posts
    580
    Union, SC
    2013 Kioti CK35 HST
    Quote Originally Posted by Sherweld View Post
    ...my rear tires which weigh some 120 pounds dry...
    120 lbs...dang looks heavier than that. I had a flat on the front of mine and it felt like more than 120 lbs. I'd have to call somebody if the back goes flat I reckon.
    But yeah, nice thingee there, bet you've got all kinda nice tools down in the la-bor-atory.
  5. #5
    Veteran Member alchemysa's Avatar
    Join Date
    Oct 2006
    Posts
    1,395
    South Australia
    Kubota B1550HSD
    Doesn't look too 'dirty' to me. That's pretty clever using the jack under the lever arm.
  6. #6
    Join Date
    Jul 2003
    Posts
    231
    If I ever get a second set of tires, I plan on investing in one of these.
    Northern Industrial Dual Wheel Dolly — 3/4-Ton | Wheel Dollies | Northern Tool + Equipment
  7. #7
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    I had in mind to build something similar to the Northern Tool unit; but your idea looks like it will work just as well.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  8. #8
    Join Date
    Jul 2005
    Posts
    1,302
    lower part of Md.
    JD310, ASV RC-100
    That is a nice setup. For just a couple dollars more (), Garrett Wade
  9. #9
    Join Date
    May 2008
    Posts
    174
    Allyn, WA
    Kubota B7100
    Thanks
    Quick and dirty means that the only out of pocket was $2 at local goodwill for the jack. The rest is mostly somebody's discarded stair stepper rescued from the blackberries, and other odds and ends. ("one mans junk, another mans treasure" LOL) This rig pretty light duty, but then I figured anything I would do with it would be less than 200#.
    Two minor things learned; The handler wheel pictured, is a very hard plastic composite of some sort which is a bit "slippery" when managing/balancing a heavy steel tractor wheel. I will probably skin it with inner tube rubber "tire" or find another wheel with a bit more "traction".
    The other minor issue is swivel casters instead of rigid, might possibly allow better handling, particularly in maneuvering heavier tires.
    Other than that, it works well enough that I even painted it!
    Regards
    Sherweld
  10. #10
    Platinum Member firemanpat2910's Avatar
    Join Date
    Feb 2006
    Posts
    901
    Havana Fla
    Ford 2910II
    wrap a layer of that stair step tread tape to your slick wheel?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
