Page 6 of 12 FirstFirst ... 3456789 ... LastLast
Results 51 to 60 of 116
  1. #51
    Silver Member DWCox's Avatar
    Join Date
    May 2008
    Posts
    112
    Northen Virginia
    John Deere 790
    Default Re: Tree Puller for hard to get at trees
    Saw something similar to the rim concept years ago in an old picture of how farmers used to pull stumps with horses. They would take a short but thick log with a stout branch proceeding from it. They would then lay the log on its side and snug it up against the stump with the branch up in the air. A cable was secured from the base of the branch down around the stump. The horse just simply walked forward with a cable pulling the top of the branch down.
    DCox
    2005 John Deere 790
  2. #52
    Join Date
    Feb 2001
    Posts
    1,447
    South-central Michigan
    New Holland TC40D
    Quote Originally Posted by rhett View Post
    the chain over rim is not rigid, so no mechanical advantage.
    Rhett
    Well sort-of and No. With the rim placed right up against the tree, there is a 2 to 1 advantage. This is derived from the fact that the radius of the rim (distance from fulcrum to tree) is 1/2 the diameter of the rim, which in fact serves as the larger lever arm. It really functions exactly the same as the bipod, until it moves away from the tree. The farther it moves, the less advantage there is. All bets would be off if the wheel was turning about it's hub axis, as if it was a huge fixed pulley, but it is not.
  3. #53
    New Member jonstark's Avatar
    Join Date
    Dec 2008
    Posts
    19
    western massachusetts
    Kubota L3010, HST, Ford NAA, Cat D7, Cat D3B
    Just bought a grubber from e-bay for $64 shipping included. There are three left. See or search for item # 300285688631
    Happy weeding!
  4. #54
    Gold Member
    Join Date
    Jun 2008
    Posts
    320
    Louisiana
    IH-1086 and a GRAY
    Quote Originally Posted by djradz View Post
    agreed, except that.
    if pull chain is draped over the rim, the rim is acting as a large pulley, no advantage due too the chain not being fixed to define fulcrum.
    if pull chain has a full wrap around rim (as others have suggested), then yes I see an advantage because a fulcrum is defined.
    I fully agree to the wheel rim idea, being an easy way to get the job done for those with enough tractor pulling. My little YM just does not have the stuff to go after the larger jobs, so I must resort to the advantage of increased leverage. To bad for me, that with a rim I can only go after smaller stuff, it is much easier to use.
    Rhett
  5. #55
    Join Date
    Jun 2006
    Posts
    50
    Decatur, IL
    B3200, M7040, ZD331
    Quote Originally Posted by jonstark View Post
    Happy weeding!
    Now there are only 2 left! Thank you!
  6. #56
    Veteran Member wedge40's Avatar
    Join Date
    Oct 2007
    Posts
    2,216
    I've read this thread would like to see one in action? Anybody have any photo or better yet a video?
    Wedge
    1967 Ford 4000,Mahindra 4530 with FEL and BH, Box blade, straight blade, FEL, Rake, Bushhog, Backhoe, Jinma chipper, KKII tiller, Grapple. Mahindra 4530, with FEL and Backhoe.
  7. #57
    Gold Member
    Join Date
    Jun 2008
    Posts
    320
    Louisiana
    IH-1086 and a GRAY
    dang wedge40, i guess late is better than never.
    my little cut strains but it worked, a full size tractor would be ideal.
    check out the Tap Root in pix 5
    Attached Thumbnails Attached Thumbnails Tree Puller for hard to get at trees-bipod_4inch_pull_01-jpg   Tree Puller for hard to get at trees-bipod_4inch_pull_02-jpg   Tree Puller for hard to get at trees-bipod_4inch_pull_03-jpg   Tree Puller for hard to get at trees-bipod_4inch_pull_04-jpg   Tree Puller for hard to get at trees-bipod_4inch_pull_05-jpg
  8. #58
    Join Date
    Mar 2008
    Posts
    590
    Seems to me that you could put a cross piece half way up the A frame, attach the chain there for the first pull and have some real mechanical advantage. Switch the chain to the top for the final pull. Tractor wouldn't work so hard and you could tackle bigger trees.
  9. #59
    Silver Member woodchuckcanuck's Avatar
    Join Date
    Jul 2009
    Posts
    248
    Loch Katrine, NS, Canada
    still looking
    Here's a pic of those wheel loaders from days gone by.
    Attached Thumbnails Attached Thumbnails Tree Puller for hard to get at trees-load3-jpg
  10. #60
    Join Date
    Jul 2009
    Posts
    248
    still looking
    And speaking about fulcrums and pivot points, this one always gives me a chuckle
    Attached Thumbnails Attached Thumbnails Tree Puller for hard to get at trees-cant-lift-jpg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
