09-26-2008, 05:27 PM
#11 (permalink)
| | Silver Member
| Re: Loader pin root grapple Rob -
All of the pivots will have 1/2" long x 1" I.D. 1/4" wall tubing (shown in blue) welded to the brackets to help keep the pins from ripping through. That is how my loader bucket is built (except on 1/4" plate), and it shows no signs of stress at the pins.
If you guys want to play with 3D, your programs should allow you to create a shape (like a circle or rectangle) and specify a depth for that shape. You may need to enable 3D first, but when you do you should be able to change the view to top, front, side, isometric, etc. and see the 3D part. Once you can do that, making more complicated parts just takes practice (and a little thought). Learning how to place parts next to each other by changing the origin point and using snaps comes next. Just work with it, and you'll get better. Ask questions, too.
I decided to model the cylinder and hoses when I thought about posting the design for you guys to review. I figured I needed to learn how to do a hose anyway, and the cylinder was pretty easy (it *is* made of simple cylinders) except for the fillet welds at both ends. I kind of just filled the space since it doesn't really show anyway. Besides, the more detail I add, the more you can review. The only problem is that it is not really Kubota orange...
Regards,
- Just Gary |
09-27-2008, 12:43 AM
#12 (permalink)
| | Super Member
Join Date: Oct 2005 Location: Foothills of the Giant Sequoia's, California
| Re: Loader pin root grapple Thanks Gary,
I couldn't tell if those blue objects in the pivot were pins only or pins and bushings. I was going to suggest using a bushing but you already thought of that.
Someday I'll start practicing with the 3D and solid modeling features. You all are posting some excellent drawings and mine look stone age.
__________________ Rob-
...The Older I get...the Better I Used to be... |
09-27-2008, 02:20 AM
#13 (permalink)
| | Veteran Member
| Re: Loader pin root grapple The biggest trick to doing any 3D work is first learning to navigate the program's 3D space. After that, one then becomes proficient at modeling. when I was teaching myself 3D, I had a pretty structural connection detail in plan view. Then I switched to an isometric view and I had parts everwhere in the Z-axis. That's when I said to myself, "Slow down, learn to navigate, then learn to model."
I use a lot of 2D shapes that are extruded into 3D, followed by the Boolean operations of Add, Subtract and on occassion Intersection.
The composite picture shows a 1970's vintage Kenworth 953S tractor and the Clark BD100000 (100,000 pound rated) axles. I did the axles in 3DS MAX, which makes AutoCAD look easy. I keep hoping to get back to this modeling project. |
09-27-2008, 08:23 PM
#14 (permalink)
| | Silver Member
| Re: Loader pin root grapple 3RRL: I knew at the time that the blue bushings would confuse someone, but left them blue for clarity. They do make a lot of sense though, because they distribute all of that point stress out to the flat part (plus provide a much larger wear surface for the pin).
mjncad: I agree completely about mastering 3D views and workplanes. I did the same thing at first. As I got better I learned how to cut parts to fit each other instead of just letting them overlap. I would say that the most frustrating thing is learning the little gotchas inherent to your chosen program (usually relating to that third plane that you don't see). That's great work, by the way.
I've saved up my lunch money for a while and intend to buy a 3-axis CNC mill this year. I have cobbled all of my milling work for years (on a 1958 Shopsmith model ER), and I'm ready for a real mill. I decided to jump straight to CNC, and will probably get the 4th axis drive along with it. I'm leaning strongly toward the PCNC-1100 from Tormach.
I can't think of a better reason to master 3D CAD than to work up to 3D CAM, at which point a fella could build just about anything that would fit on the table...
Regards,
- Just Gary |
09-27-2008, 08:24 PM
#15 (permalink)
| | Silver Member
| Re: Loader pin root grapple mjncad: Oh, and I especially like the 3D models in front of the tire in the lower right photo...
- Just Gary |
09-27-2008, 09:15 PM
#16 (permalink)
| | Veteran Member
| Re: Loader pin root grapple Quote:
Originally Posted by JustGary Keep in mind that it is a 48" grapple for a 28 HP Kubota with the LA463 loader. | I agree, very nice 3D renderings, JUST.
I use a cheapo program called DeltaCAD, but only for 2D. I never tried
the 3D capability. I am only using it to communicate with a CNC plasma
cutter anyway.
As for your design, you can increase the curl forces by using the larger
loader arm pivot spacings that your drawing shows, but you will have to
eliminate the links your FEL uses betw the curl cyl and the loader arm.
Make sure you allow for that or your grapple will not curl enough. I had this
same issue with my fork frame.
Your FEL bkt is 1/4" thick? You must have an HD bucket and they can be
very heavy.
__________________ See my TBN projects at: http://mysite.verizon.net/resyfcgt/
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Diesel fuel dispenser
Bucket dentistry
custom hydraulic b/h thumb
adapting a 4-in-1 bkt to my Kioti
JD 4300 rebuild (new!) |
09-28-2008, 02:19 AM
#17 (permalink)
| | Veteran Member
Originally Posted by JustGary mjncad: Oh, and I especially like the 3D models in front of the tire in the lower right photo...
- Just Gary | I'm fond of those 3D models too. |
09-28-2008, 01:12 PM
#18 (permalink)
| | Silver Member
| Re: Loader pin root grapple dfkrug: I should learn to measure before I type. The vertical leading edges of the bucket are 1/4", but now that I have actually measured it, I see that the rest of the bucket is 3/16". I had always just glanced at the sides and assumed that the other parts looked a bit thinner because they were made on a metric roll...
That means that the pin brackets on my bucket are 3/16" also. I can see where I can lighten this design considerably by using thinner plate for most of the gussets. What I don't know is what grade steel Kubota used for the bucket. I'm assuming mild steel will do, except for the pin bushings.
I used the same curl cylinder spacing and angles as my loader bucket, so I expect the same amount of curl from the rake. I did bias the bottom tines downward just a little, because I'm OK with loosing a little rollback in favor of more "dump" so the grapple will have plenty of opportunity to pick up logs and other things on the ground. I'll check that again before I cut metal.
And if I had your CNC plasma cutter, I probably would have cut metal by now...
Regards,
- Just Gary |
09-28-2008, 05:37 PM
#19 (permalink)
| | Veteran Member
Originally Posted by JustGary dfkrug: I should learn to measure before I type. The vertical leading edges of the bucket are 1/4", but now that I have actually measured it, I see that the rest of the bucket is 3/16". I had always just glanced at the sides and assumed that the other parts looked a bit thinner because they were made on a metric roll...
And if I had your CNC plasma cutter, I probably would have cut metal by now... | A CNC milling machine will make my plasma cutter look cheap. My PC is
manual only...I send out DXF files to a shop in LA for repetitive cuts.
When my previous Kubotas had an OEM bkt, they were the standard duty
ones with only 1/8" carcases and 1/2" plow steel cutting edge. Kub has a
HD bkt option for other L tractors and they have reinforced top lips and
sides. Maybe thicker carcasses. Sometimes QA attachment.
Mild steel is fine for everything but the cutting edges, which should be
plow steel. As for the bushings, my guess is the 1" ID, 1.5 OD DOM tubing
used here is also mild steel. I use .75-1" bushing lengths and weld them
into 1.5" holes in the brackets. Since you are doing a grapple, you might
consider using plow steel or replaceable teeth on your tines. Rocks wear
out A36 mild steel pretty fast.
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
09-28-2008, 06:01 PM
#20 (permalink)
| | Silver Member
| Re: Loader pin root grapple dfkrug: This is the only bucket I was offered by the dealer, and it does have a 1/2" carbon steel edge, but is 3/16" for the main construction instead of 1/8". I'm impressed with its ability to take a deliberate beating (ramming trees, for example) and only get the paint scuffed off.
I may try to fit the bushing in a 1 1/2" hole, but that's a lot harder to drill than 1" is. If I can get the mill first, the holes won't be a problem at all. Neither will accuracy. The problem is that I would really like to have the rake and grapple now (well, OK, I'd like the mill now, too).
I'm leaning toward A36 steel for the tines because I'm in Florida and the only rocks I ever see had to be purchased or I have to drive somewhere else to see them. If I need hard faces I figured I'd just zap them with hardened rod and let them go. I do have sand, though, and trees. I rinse my loader every time I use it, and grease the heck out of it also. The pins are already getting a little loose fitting. Did I mention the sand?
Regards,
- Just Gary |
