Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-16-2008, 11:42 AM   #1 (permalink)
DMF
DMF's Avatar
Default Hay wagons; let's see them!
I just picked up a Gehl running gear; not sure of the model but it's about 12' from axle to axle (adjustable) and about 6 1/2' wide from tire to tire. I am going to build a wooden/steel body on it for hauling small square bales. My partner has a similar set-up and the body on his is approx. 15' long by 9' wide. I can copy his pretty much, but I was wondering if anyone knows of any plans available that would be helpful. Also, I'd love to see some pictures of what other TBN members use/have created in case there is some design feature you may have that would be beneficial to me.
So let's hear what you've used (materials, sizes, etc.) and better yet, post some pictures up as well!
Thanks!
DMF is offline   Reply With Quote
Old 10-16-2008, 12:52 PM   #2 (permalink)
GBeck's Avatar
Default Re: Hay wagons; let's see them!
great thread idea....what I want (but don't have yet) is a few hay wagons roughly 10x6 and only roughly a foot off the ground that I can just park in the field and throw the hey on as it comes off the baler. then just park in the barn
current set up requires moving the hay 2 - 3 times and is a real PITA
GBeck is offline   Reply With Quote
Old 10-16-2008, 01:05 PM   #3 (permalink)
My hay wagon is an old David Bradley sold by Sears and Roebuck... 1950's.
mark
__________________
red tractor
blue tractor
green tractor
orange tractor
too many impliments to list
mjarrels is offline   Reply With Quote
Old 10-16-2008, 01:07 PM   #4 (permalink)
Gold Member
Me too! A wagon is going to be one of my winter projects and I need ideas as well.
Please, some of you "haves" share with the "have nots" !!!
HappyCPE is offline   Reply With Quote
Old 10-16-2008, 01:30 PM   #5 (permalink)
http://www.tractorbynet.com/forums/b...e-trailer.html
This is what i built last year: Its a hybrid, built from a 3 ton Miedema walking tandem manure spreader, and a Doornwaard 2 ton turntable steered highway trailer.
__________________
Free scrap is a good investment !!!
__________________
1967 Zetor 3011, rebuilt trans, engine to be rebuilt this summer
1986 Zetor 5245, my old man's tractor, i just own the loader
1998 Volvo S70 TDI
2007 Volvo 440 1.9 TD based dirt buggy, under construction
Renze is offline   Reply With Quote
Old 10-16-2008, 04:52 PM   #6 (permalink)
Member
Chances R's Avatar
Not much to look at. I bought this water mellon wagon a few years ago. It works great for a hay ride, and I use it for our wagon backing competition. I would like to get one that has hoist next time.
Chances R is offline   Reply With Quote
Old 10-17-2008, 07:39 AM   #7 (permalink)
DMF
DMF's Avatar
This isn't the greates picture, but this is my partner's wagon. We can put 130 small bales on it comfortably but we've gone as much as 150. The barn where we store the hay requires that the wagon be backed in, slightly uphill, with a drop off about 5' to the right of the driveway leading in! What we do is unhook the wagon once we get there and re-hook using a hitch on the front of the tractor and then "push" the wagon in. Backing up a 4-wheel wagon is not all that easy; hitching it to the front of the tractor allows for quicker corrections. The problem when we go more than 130 bales is the weight; trying to push the wagon uphill and into the barn is tough enough; going an extra 20 bales to get 150 tends to be the point where the wagon sometimes pushes the tractor!
I gave the dimensions for this wagon in my first post. It has two 4x7 Ash beams that run front to back. Perpendicular to that are Ash 4x4's spaced 2' on center. The deck is made with 1" thick Ash boards. The front and rear racks are also Ash for the most part. The front and rear racks are where I plan to make some improvements; his are pretty beat up. They are somewhat flimsy and we've cracked an upright more than once. I may go with steel for my racks, but I'd like them removable so during pumpkin season I could put some shorter sideboards on like Chances R's melon wagon.
Let's see more pictures and hear your construction details!
Old 10-17-2008, 09:23 AM   #8 (permalink)
jayste's Avatar
Location: Close to the Oklahoma hills where Woody was born
DMF, I can relate to your pain of handling "small" square bales of hay. First thing I'd do is get that poor fellow who's "bucking" those bales up onto that wagon a pop-up loader. Usually found around here at auctions for pennies on the dollar. Believe me, they're worth their weight in gold to a hand who's over forty and no longer can (or want) to keep up with those young, flat bellied, kids who we once were. That is provided you can find one who's willing to haul or load a bale of hay nowadays! Anyway, I'm rambling. I haul mine on 16' utility trailers so I may be talking out of turn here but I like your idea of staying with a wagon. I know what you're saying about backing a wagon, it's not the easiest thing to do. We have one similar to what you described but it's converted to a "covered wagon" now with seat, bows, a sheet and two good sized mules to pull it. Like I said our running gear is similar in size and build but your friends is built more for hauling some serious weight. Copying his might work unless you want to replace the wood with some heavy walled box or rectangular tubing or channel iron. We actually were able to retrofit our with rear disc brakes with a small ball valve in line by the seat to lock the brakes while parking. Bear in mind they aren't vacuum assist!? Kind of like the not-so-old days! I know this doesn't seem too informative but some sort of brake or chock might alleviate the wagon from pushing the tractor back while parking it in the barn.
jayste is offline   Reply With Quote
Old 10-19-2008, 11:46 AM   #9 (permalink)
Gold Member
It's not very pretty but it picks them up and stacks them....and I don't have to get off the tractor.
Mike120 is offline   Reply With Quote
Old 10-19-2008, 10:13 PM   #10 (permalink)
New Member
I don't have any pics of hay wagons, but I have a few tips for useful features.
The three hay wagons my father had were built by himself and his father in the year 1958. We used these wagons until 1995 when they were sold at auction. I don't recall the auction price, but I do know it was quite high, especially for 40-year old wagons.
Our wagons were built on Electric brand running gear (Electric Wheel Company, Quincy, ILL), which were always my favorite for ease of maintenance and ease of use while hitching and unhitching - versus Gehl or John Deer running gear which I disliked.
The two reason why these wagons (and all my father's equipment) lasted for 40 years is because 1. No exposure to the weather -- we parked the wagons in the barn at the end of every day and never left them in the field. 2. Regular maintenance -- my father would meticulously service each piece of equipment before using it. Lubrication, bolt tightening, parts replaced, etc.
Now, on to features I always liked about these wagons:
As a farm boy, I often helped other farmers with their haying or we would occasionally lend out/borrow other farmers' wagons. So, I got to work with many different types and designs of hay wagons. I always liked my father's wagons best.
1. Made of Wood. I prefer wooden hay wagons.
2. Rough-cut lumber. Our wagons were made of rough, unfinished boards that did get smoother over the years. This prevented foot slippage or falling down while loading or unloading hay bales.
3. The front opened. Our wagons opened in the front with the front panel mounted with barn door hinges. The front panel opened downward towards the wagon tongue and was the perfect height to be supported by 2 hay bales on their sides on each side of the wagon tongue. When closed, we secured the front panel with a chain and a common chain tightener.
With the front panel opened and resting on 4 hay bales, we could then unload the wagon. No removal of bales was required - just open the panel and get to work. The open panel was now the elevated platform to stand on to reach the hay elevator. It worked perfectly. The only issue was falling off the front of the wagon if you weren't careful.
I worked on a lot of other wagons that did NOT have a front-opening door and I hated them. With a front-opening door, the hay wagons were useful for other applications, such as transporting or storing other items.
4. Side-openings. Our wagons had side openings that were in the center section (our wagons had 5 vertical posts). These side openings were closed with lumber that was a few inches longer than the gap. Ours had hook-and-eye closures with small pieces of sheet steel to keep the door in place when opened. The side openings made it easy for a man to get in and out of the wagon and made it easy to kick out the loose hay chaff.
5. Correct height. Our wagons were just short enough so that we could park inside the barns. In fact, we used to drive the entire tractor and wagon INSIDE the barns and drive right up to the hay elevator. I never got a sunburn unloading hay on my father's farm.
Here is a tip for ANY hay wagon or light-weight wagon: When you want to park them inside barn and they are empty -- unhook from the tractor and back them inside the barn using only human power. So long as it's not uphill, it makes the task quicker, easier, and prevents damage to the barn or the equipment.
barefoot_gardener is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.08425 seconds with 9 queries
