Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Default Truck canopy removal ?
    My new (to me) truck.
    For canopy removal, my only options at the moment are calling in 3 friends or running down to 'canopy corral' and have them forklift it off and store it.
    How are others removing their canopies ?
    ::Sent from a standard desktop keyboard::
    My Photobucket
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Veteran Member crbr's Avatar
    Join Date
    Apr 2007
    Posts
    1,667
    East TN
    Kub - 2K6, B7800
    Default Re: Truck canopy removal ?
    I lift mine off upon my shoulders, centered under the top. Walk it right off onto a portable (casters) Gorilla (brand) shelf that is about 6' high. Set it on the top part. Done deal.
    The front end loaders can be used with fork extensions.
    For me, just as easy and quick to offload on my shoulders. Mine is fiberglass and isn't that heavy.
    ** Kubota **
    Psalms 86
    John 1:12-13
    Duraflap / Kaydenco not worth a hoot for service or products.
    "Google" is a proper noun, not a verb.
    If you mean what you say, then say what you mean, or just don't say anything
  4. #3
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Quote Originally Posted by Willl View Post
    Well, that's out. Just called them to find out what their fee was and was told "no longer offered"
    Quote Originally Posted by crbr View Post
    That ain't happening. I'm guessing mines around 250-300 lbs.
    My Photobucket
  5. #4
    Gold Member Lasgambler's Avatar
    Join Date
    May 2007
    Posts
    292
    West Coast of Arizona
    YANMAR FX42d
    [QUOTE=crbr;1504685]I lift mine off upon my shoulders,
    I too, have removed mine in this manner, and it was a heavy A.R.E. work top with side doors and bins,
    If you build a rack about 3 to 4 inches higher than your truck bed and back up close to it you can get inside and raise the back of the canapy and slide it onto the rack. Just go a little at a time and you can do it.
    YANMAR FX42d, Koyker 155 FEL, ROPS w/Canapy, Top & Tilt Gearmore BS w/ Hydraulic Scarfiers. Loaded R4 Industrial Tires, Princess Auto BH w/ Subframe. Boom pole. Pallet Forks.
  6. #5
    Gold Member
    Join Date
    Dec 2007
    Posts
    391
    I built a set of A-frames, and used a pipe and ropes to lift the top up. I'd lift it a little and put a 2X4 under it, tie the ropes to the pipe, and turn the pipe with a crank to raise the top. I just let it hang there unless the weather was rough.
  7. #6
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    I was wondering......I've got this gizmo and a 7' piece of 2" receiver stock.
    Can ya hear the gears turning ?
    My Photobucket
  8. #7
    Gold Member davkir's Avatar
    Join Date
    Sep 2005
    Posts
    354
    Hendricks Co., In
    JD 2305 W/CC & R4
    Or use a large tree limb.
    Attached Images Attached Images
  9. #8
    Platinum Member JDeerekid's Avatar
    Join Date
    Sep 2004
    Posts
    877
    P-Town, Upstate New York
    Montana 4340C w/Loader, JD GX345 w/54in. mower
    Just get a a buddy to help. You on one side and him on the other and take it off. I use to set mine on our picinic table it fit perfect to keep it off the ground.
    Montana 4340C w/loader, AgroTrend FU78 rear snowblower with hydraulic shute rotation, Horst 48" pallet forks, 3pt. 2-bottom plow, 6ft. bush hog rotarty cutter, 3pt. Woods 7ft back blade, 3pt. cultivator, 5ft 3pt. york rake, 6' KKII tiller, JD494 4-row planter. Future attachments: backhoe, grapple
  10. #9
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Quote Originally Posted by JDeerekid View Post
    That's what my brother and I do with his canopy.
    His is a little shorter in height, and yet I still end up adjusting my shorts afterwards. It's heavy. I can only guess mine is even more.
    My Photobucket
  11. #10
    Join Date
    Apr 2007
    Posts
    1,667
    East TN
    Kub - 2K6, B7800
    Well, without getting into personal stuff, I lift weights as a hobby so maybe I may have made assumptions without thinking.
    I have a Leer top, glass all around and I suspect this one will go 200 + lbs but it isn't that bad lifting it just off the bed and then back a step or two at a time. Just saying....
    About the only time I remove mine is to wax it and clean out the bed of the truck. I remove it even less (than the previous top) since I got the fold-down front window in the top, allowing access to the outside of the front topper window and the outside of the rear cab window, for cleaning. Best option I have ever seen for a topper.
    ** Kubota **
    Psalms 86
    John 1:12-13
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
