HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-27-2008, 05:45 PM   #21 (permalink)
Default Re: Interesting Welding Statement.
Quote:
Originally Posted by Flatheadyoungin View Post
when you hammerweld, the weld is actually is being forced to move.....since mig is a hard weld, it cracks...
when you bend something, the metal around the weld is what does most of the moving.....so the pressure is spread out...
well, at least in my thinking
The metal STILL remains in a semi plastic state for hammer welding. Its not room temp cold.. Whether its heated with an OA torch..an electric furnace..MIG welder or ,,whatever...its still "red hot" right prior to hammering into "final shape".
If ya think MIG welded items get cold quickly.......Ive got a nice set of leather gloves with scorch marks to show you!
__________________
Kubota B3030 with 40 amp alternator kit; LA403 FEL; 60 inch backblade; sub-soiler; ballast box; EzMover hitch; Payne clamp-on bucket forks; a HD set of smaller discs and a 60" landscape rake with dolly wheels
Hobart HH210 Mig welder
Sully2 is offline   Reply With Quote
Old 10-28-2008, 02:49 PM   #22 (permalink)
AlanB's Avatar
Quote:
Originally Posted by Sully2 View Post
MANY items are Mig and TIG welded on airframes...far too many to attempt to list for sure.
Only airplanes Im semi familiar with are combat aircraft. F16;F14;F15...etc
I believe the statement was MIG welded, and while I am not knowlegable with the aircraft models you mentioned, I have seen an airfield after sleeping at a Holiday Inn and cannot think of a single MIG welded component. (and yes I am a licensed Aircraft sheetmetal guy)
Also, in the reference to propane tanks, while there are some Mig welded (I believe only the NRC type) the vast majority of them are done with the sub arc process
AlanB is online now   Reply With Quote
Old 10-28-2008, 03:53 PM   #23 (permalink)
I've been in the heavy steel industry for 7 years now. As a rookie i got the nicest jobs, like cleanung up and throwing away the unused welding rods.
They only used hardfacing welding rods for small jobs, because its easier to change rods than wire rolls and gas.
At that time we made structural construction steel, and waste recycling plants.
Where i work now, we make wheel loaders. All MIG welded, i just dont know if they use the same wire for welding NAxtra 70 shovel loadframes as for standard S235 radiator supports, because our heavy steelwork is outsourced to Slovakia because of the cost of labour, and the Asian competition in the market.
__________________
Free scrap is a good investment !!!
__________________
1967 Zetor 3011, rebuilt trans, engine to be rebuilt this summer
1986 Zetor 5245, my old man's tractor, i just own the loader
1998 Volvo S70 TDI
2007 Volvo 440 1.9 TD based dirt buggy, under construction
Renze is offline   Reply With Quote
Old 10-28-2008, 04:48 PM   #24 (permalink)
Elite Member
wushaw's Avatar
I agree with ya AlanB.
I have held a valid A&P since 89 and worked on DC9, DC10, DC8, B727, B737, B757. Currently B737s.
I have done alot of sheetmetal work on DC9s and quite a bit on B737 in heavy checks, light cks...etc
The only welding on any of these aircraft I know is TIG on titanium ducts and door sill plates on entry door openings and cargo door openings.
The rest of the structural part of the airplane is sheetmetal and composite held together with rivets (soild & cherry), hi loks, hucks, bolts and glue for the composite part.
__________________
Kubota L2800HST, Mitsubishi 372, bh75, 45" Agric tiller, 5' home made disk, 42" Bush hog, PHD, 66" Cammond BB.
wushaw is offline   Reply With Quote
Old 10-28-2008, 05:57 PM   #25 (permalink)
bobodu's Avatar
You gotta remember how some guys will argue MIG all day long,but if you read back far enough,they will plainly admit that they can't strike an arc in the first place!!!
__________________
1945 Allis-Chalmers,1967 Wheelhorse.The wife has a bubble hooded Simplicity and a Dixon.
Anything green here- has roots or gets spent!!!
bobodu is offline   Reply With Quote
Old 10-28-2008, 08:22 PM   #26 (permalink)
Quote:
You dont have to read back any distance to find me admitting that. I cant strike an arc worth a flip. I cant mig weld very pretty either. I can weld something for my use and although it might not work pretty it holds together well and that is why I weld things is to hold them together. These guys that make things and know what they are doing is great. There are a lot of us on this website who dont make hotrolled cylinders. Airplanes or even Propane tanks, we just fix things that we broke on our tractor equipment or we fabricate small items. We get along just fine with a mig. If you have the budget for one then why spend a lot of time learning to arc weld correctly. Life is too short. Grab a mig and some steel and enjoy.
gemini5362 is offline   Reply With Quote
Old 10-29-2008, 01:17 PM   #27 (permalink)
The above mentioned aircraft..along with the F18...are the mainstay combat aircraft presently used my the US Armed forces...??
Onlt thing I knopw about the SHEETMETAL on the fuselage is that typically its RIVETED on..or held in place with 1/4 turn fasteners..!
__________________
Old 10-29-2008, 02:13 PM   #28 (permalink)
AlanB's Avatar
Sully I did not say I did not know what those aircraft were, I said I was not Knowledgable on them as in I have not had direct working experience on those airframes, and from the sound of your post, I wonder how much direct airframe work you have done on them.
That said, most of my experience is Rotary Wing, UH-1, AH-1, UH/MH-60, CH/MH-47, OH/AH-58, AH-64 and just a touch of killer eggs.
So my question again, as your statement said there are MANY Mig welded pieces on those aircraft, and I would assume that you have knowledge I don't, please just give me an example of one or two so that I can increase my knowledge in a field that I thought I was vaugely familiar with.
Thanks
Old 10-29-2008, 03:03 PM   #29 (permalink)
Back to your tank, We used to sub arc boiler shells 20 years ago, the machine made a top(outside) pass, then the operater would gouge out the inside and run an inside pass. All welds were x-rayed and stamped. (ASME IX)As to downhand spray-arc on your tank? IMHO, the cert test is rigged because they required you to run multiple passes quickly thereby getting around the issue of cold fusion. Those welders who let the work cool failed miserably. The tank may by light enough guage to run mig on and get good fusion, but I would not do it downhand... and it will be brittle.
mbohuntr is offline   Reply With Quote
Old 10-29-2008, 03:14 PM   #30 (permalink)
Elite Member
wushaw's Avatar
Thanks
LOL Now that's funny
Sully; the last time I looked at a F18 sittin on the ramp I seen nothin but hi loks holdin that thing together, Douglas...now Boeing (who built the F18) loves these things called hi loks. Titanium is a favorite and a complete &%$#@ to drill.
1/4 turn fastners are what are used on non-structural panels.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.41754 seconds with 9 queries
