Results 1 to 4 of 4
11-16-2008, 09:23 AM #1
Built a new log lift
Built a new log lifter for handling the big stuff and loading it onto my wagon or splitter. It's built out of scrap 3" channel, with one bolt and a little left-over chain. Most of my logs cut to 20" so I built this to pick up 22" and less. With another hole drilled for the pivot, I can always adjust it for bigger logs. I did the welds with my little Campbell wire welder.
Other pics available at Paul Weisblatt's Photos - Getting in the firewood | Facebook[#] Window Geek
When my wife said, "You've waited long enough for a tractor. Go get one.", I knew exactly what to say:
"YES DEAR."
Kubota B7610 HST 4WD
LA352 FEL, B2765A front blade, 3 pt carryall, bucket forks, spreader, lifting boom, 2" receiver, TSC PHD, KK II 4' rototiller, Salsco chipper, towable splitter, homemade 3 pt pallet forks, 7' back blade, 6' yard rake w/ homemade gauge wheels, HF Quick Hitch
11-16-2008, 09:29 AM #2
Re: Built a new log lift
nice set of tongs. However, maybe you could put some teeth on bottom of the c channel to build in a safety factor for a better bite ? I bet that if you tried to pick up a frozen log, with snow/ice it will slide right off.
11-16-2008, 09:47 AM #3
[#] Window Geek
"YES DEAR."
11-17-2008, 11:08 AM #4
Window Geek,
I just sent you a PM about you front auxiliary light.It's the going that counts, not the distance!!!
