Results 1 to 5 of 5
  1. #1
    Silver Member Dale1995's Avatar
    Join Date
    Jul 2008
    Posts
    163
    Caribou,Maine
    John Deere 2320
    Default Fork lift Frame
    I am in the process of building a set of forks for my 2320 John deere tractor, I just purchased a set of 1000 lb capacity forks from a supplier, since my tractors lifting capacity is only 989 lbs, I figured that the forks would be plenty strong. My question is I am going to build this fork lift frame out of 2" x 4" rectangular tubing, in order to keep the weight down I am planing to use 3/16 " wall thickness, instead of 1/4" thickness. Tubing is very strong, has any one out there done this and what is your opinion? Will this be strong enough for my needs? Thanks for any help.
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,924
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: Fork lift Frame
    I think the 3/16" will be fine.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Join Date
    Mar 2006
    Posts
    111
    South of Perth, Western Australia
    Iseki TU155 Landhope
    I could do with a fork lift on my "little blue thing" -what did the forks cost you?
  4. #4
    Join Date
    Jul 2003
    Posts
    12,924
    Westminster, MD
    I paid $100US for my used 42" forks from a forklift dealer. They where "out of spec" for real forklift use but still have plenty life in them for a CUT.
    KennyD
    www.boltonhooks.com
  5. #5
    Silver Member Hookblock's Avatar
    Join Date
    Nov 2007
    Posts
    201
    WI
    JD 4310
    I don't know if this is what you are looking for. I used 2''x4'' 3/16'' for the top and bottom. 3/8''x 4'' for the sides, and 6'' x 1/4'' channel for the loader mount. 1 3/4'' round for the forks, that are old brick forks.
    Attached Images Attached Images
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
