HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-27-2009, 11:29 PM   #101 (permalink)
Default Re: cab project
HEAT!!!!! installed my heater today i could not believe the whole kit was made in USA. it even came with a template to drill all the holes, made it very easy and fast. the only disapointment was that i could not mount the switch in the dash minimum 3" clearance for the heat resistors on the back of the switch so i made a bracket. the switch has hi,med,& low. i had to put cardboard in front of the radiator to get good heat, hopefully this will be enough when it gets cold.
cab-project-100_1106.jpg  cab-project-100_1107.jpg  cab-project-100_1108.jpg  cab-project-100_1109.jpg
Dirtnut is offline   Reply With Quote
Old 10-28-2009, 03:09 AM   #102 (permalink)
mjncad's Avatar
Quote:
Time to make a set of shutters like the big rigs have! That would be a cool project.
__________________
Measure it with a micrometer, mark it with chalk, cut it with a torch, beat to fit, paint to match, inspect it with a microscope.
Google finally fixed Picasa web albums problems I was having. Latest postings.
http://picasaweb.google.com/mjncad/HydraulicsUpgrades#
http://picasaweb.google.com/mjncad/ToolsPower#
mjncad is offline   Reply With Quote
Old 10-28-2009, 09:25 AM   #103 (permalink)
that would be cool. the radiator has a removable screen that slides in a groove i think i will make something that replaces the screen for winter.
Old 10-28-2009, 08:00 PM   #104 (permalink)
NH-Rob's Avatar
I have been thinking about you heater install pictures. I see that you have the return line going into the top radiator hose. I would think that would bypass the t-stat and increase engine warm up time. If it was on the bottom line the warm coolant would go back into the warming engine instead of a cold radiator. What do the rest of you think about this theory?
Rob
__________________
b3200, 60" land pride finish mower, 3pt log spitter, pallet forks, lawn sweeper, bottom plow, non working pto genny.
NH-Rob is offline   Reply With Quote
Old 10-28-2009, 08:31 PM   #105 (permalink)
the thermastat is not bypassed(bad picture)the hose to the right is teed into a small hose that runs from the pump to the neck with the thermastat then is dumped into the top hose when it opens.i originally teed into top & bottom hoses with no success. so i had to plug the bottom hose tee after i cut it @#$%%^ oh well it gave me another drain.then i routed that hose to the pump.
Old 11-01-2009, 10:26 PM   #106 (permalink)
Just a little note on my cab, please dont take this as a bragging spree. I finally got the tractor out the past three days doing loader work & using my pull grader & to test the cab out with about 15hrs. With temps in the 30's i did not need the heater on just the fan to keep from fogging up.I am guessing when it gets could my heater will be adequate. I flexed the tractor over ditches & rattled the cab banging the dirt out of the bucket to try & find problem areas the only thing i found is when i put the bucket on the ground to park it puts enough pressure on the door jam striker plate to make it stick a little, this is do to the fact i have the frame attached to the loader subframe.If i float the bucket to relieve hydrualic pressure the door moves freely (cab builders keep this in mind) if attaching to loader subframes. A little grinding will take care of this.Other than that the cab is working great,but time will tell.Now we need cold & snow to put it to its real test.I will keep posting pictures as i finish odds & ends on the cab & any problems that come up to help other cab builders.
THANKS TO ALL FOR COMMENTS & INPUT ON THIS PROJECT.
Old 11-03-2009, 02:06 PM   #107 (permalink)
Gold Member
regardless of need do you mean you never even tried it just to see how well it did to see how well it worked, BTW nice job.
__________________
Bill
bpattie is offline   Reply With Quote
Old 11-04-2009, 03:58 PM   #108 (permalink)
New Member
Bragging spree, my butt!! If I could build a cab like that I'D sure be bragging!!
Nice job!
__________________
_____________________________________________
JD 2310, 62" Mid-mount mower, 52" 2-stage snowthrower, 60" HD rotary broom, 52" HD tiller
wolfmanmd is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.29855 seconds with 9 queries
