Ripper
   / Ripper #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
A few months back a truck at work backed into something and lost its rear bumper off the trailer. I ended up with the 4X4 tube that used to be the bumper.
The only time I've ever used the rippers from my KK box blade is when I'm trying to loosen up ground but not scrape it. The bumper and ripper shanks are now coming together in a home-made, make-shift ripper to loosen soil prior to tilling.
This is a picture of the materials that are going into it. I paid $5 for the two Cat. 1 TPH pins, and I paid $8 for a 7/8" hole saw. Everything else is leftover from other projects or scrap that I've picked up along the way. The one ripper is in the shop just so I can measure it.
   / Ripper
To cut the slots I've drilled holes on either side of the slot and cut between the holes with a 4" angle grinder. Once I'd punched through with the angle grinder, I used a reciprocating saw to finish the cut.
Here are some more pics of the project as it's progressing. Pardon the clutter in my shop. I really need more space and better storage out there, but it's not in the plan for a few more years.
   / Ripper #3
Can't believe you could drill that many holes in that steel w/ an $8 hole saw!! My project has me drilling 3/4", 7/8", and 1" holes through 1/4" plate. I bought the three bits, at about $17- each!!
   / Ripper #4
I am thinking that you will need to beef up the metal behind the rippers on the bottom, and on the top front. As soon as you get into something tough, that ripper is going to plow it's way out of that tube as is..
   / Ripper #5
The trick is to keep the bits cool with water , air, or cutting fluid.
   / Ripper #6
Looking good!
It is amazing what you can do with a mill... er.. hole saw!;)
   / Ripper
Thanks for the suggestions.
The top is going to be anchored with tabs welded on either side of each slot. There'll be a 1/2 inch hole in each tab for the pin that holds the ripper in place.
I've actually saved the pieces that I cut out of the slots thinking that I could weld them on underside on the back to beef up that metal.
I'm still deciding whether I should just attach an A-frame directly to this 4" tube to make the 3 point hitch attachment, or if I should come forward of the tube to make more of a platform to give the 3 point A-frame more attachment points and more stability.
   / Ripper #8
Iplayfarmer,
You said: I've actually saved the pieces that I cut out of the slots thinking that I could weld them on underside on the back to beef up that metal.
I believe you should use something more substantial, like 1/2 in thick by 1 in wide, by 2 in long.
Not to long ago, someone did something similar with rippers, and posted a picture of the rip out, and then he beefed up the unit with some extra metal.
   / Ripper
Thanks for the warning. These plugs aren't 1/2" thick, but they are just shy of 1" x 2". I do have two for each shank (top and bottom). In that first picture I also have a stick of 1/2" X 1" flat stock. Based on your recommendations, I may just cut chunks of that flat stock to stick to the bottom.
If anyone has a link to that picture of the beefed up ripper, it would save me the time of looking for it.
Keep in mind too that my tractor is only 19Hp.
   / Ripper #10
What you are making is similar to the Landpride SF2572 Scarifier. I have one of these and use it on a regular basis. The great feature of the LP unit is that it allows me to also use my rake at the same time.
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
2018 HMDE TL & 2014 VERMEER (A53421)
2018 HMDE TL &...
UNUSED RAYTREE RMBD50 - 50" DRUM MULCHER (A54757)
UNUSED RAYTREE...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
