Quote:
Originally Posted by jayste (I might get a little beat up though- they're not painted!) |
I was looking at the forks yesterday and thinking that I ought to finish them out (close all the open ends and smooth off some splatter) to get them ready for paint. Right now I would not dare leave them outside as they would be rust in seconds!! I have a list of things that need paint this spring as I made several mods to my implements so that they fit my
quick hitch. Also the Hitch itself needs some paint. At least the added time allows me to check the functionality of an implement, so that if it need a modification I can do that BEFORE paint.
It is a bit cold here yet, but maybe in May.
I was pleasantly surprised the forks were as strong as they were. By moving the lathe around now I know that the forks will handle all the 3 point will lift and more. The lathe crated weighed over 1000 lbs.
I did use the lathe to center drill the shaft the forks slide on and threaded the hole so that now I have a bolt and a washer in the end of hte shaft to retain the rod. I did not take a pic but will sometime as I finish the forks out.
You are welcome to post your pics here, but you will get more looks if you start a new thread with your construction.
Mike
