Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    Elite Member Skyco's Avatar
    Join Date
    Jul 2007
    Posts
    2,718
    SC/NC
    Default Re: Reese hitch receiver tubing undersize
    Went by TSC today to look at the receiver stock like I bought. Yep- made in China. Tried a test fit and lo and behold some of the Reese drawbars will not go in the Reese receivers. In fact I got one stuck about an inch in and couldn't get it back apart
    I took some crappy (really crappy!) cellphone pics below. Notice the radius of the internal corners in the tubing. Look closely at the 2nd pic upper right corner of the tubing The one I bought was nowhere near this bad, but still wouldn't accept some 2" drawbars.
    Attached Thumbnails Attached Thumbnails Reese hitch receiver tubing undersize-02-23-09_1040-jpg   Reese hitch receiver tubing undersize-02-23-09_1041-jpg   Reese hitch receiver tubing undersize-02-23-09_1038-jpg   Reese hitch receiver tubing undersize-02-23-09_1039-jpg   Reese hitch receiver tubing undersize-02-23-09_1042-jpg
  2. #12
    Join Date
    Jun 2003
    Posts
    1,649
    Northern, New York
    Kubota L3830 03: RTV 900
    I hope you jamed as many of them together as you could find. Like drop them on the floor. That should get your point across.
    M-5040 w/cab, 05 RTV 900, Where the maple sap flows
  3. #13
    Elite Member
    Join Date
    Sep 2005
    Posts
    3,160
    Ohio
    Case DX55, Ford 850
    My local TSC had a pile of Reese brand tubes like this marked down to half price a couple months ago. I wonder if they had this same issue and they were dumping them. I was looking for the small 1 1/4" size, but almost bought one of these since it looked like a great deal.
  4. #14
    Join Date
    Jul 2007
    Posts
    2,718
    SC/NC
    Quote Originally Posted by Deerlope View Post
    I bought The same tube at TS about a year ago mine fit OK.
    Yeah I've bought several over the years making stuff, never had a problem before.
  5. #15
    Veteran Member joes_427_vette's Avatar
    Join Date
    Aug 2004
    Posts
    1,243
    Midwest
    New Holland TC 55 DA, 4110 John Deere, HT 20 Bolens, 1456 Bolens
    Why would a person buy high priced Chineese steel products for a receiver hitch? Go to your local steel yard and find two 1/4" pieces of tube that slide together. The hole you drill will fit perfectly. With a total of 1/2" of steel your never going to experience a failure. Now you have stock to build a half dozen more !
  6. #16
    Platinum Member bobodu's Avatar
    Join Date
    Mar 2004
    Posts
    954
    Whitley County,In.EIEIO
    Farmnought.Gravely Model L,Gravely Model LI,1941 Clinton two wheeler
    I did exactly that.However...I wish I had used a commercial hitch to get the proper placement of the hole through the receiver because they won't fit the tube. Can't get the pin through the hole.Fortunately,that was for the Jeep and I just use a 2' ball on that.Got MUCH smarter on the one I made for the dump truck...
    HINT* If there is a possibility of using a tri-ball...drill both set of holes before mounting it on the truck. You can guess how I know this.....
    Be sure to wrap the end of the tube with some 3/8 flat stock too.
    1945 Allis-Chalmers,1967 Wheelhorse.The wife has a bubble hooded Simplicity and a Dixon.
    Anything green here- has roots or gets spent!!!
  7. #17
    Join Date
    Jul 2007
    Posts
    2,718
    SC/NC
    Quote Originally Posted by joes_427_vette View Post
    I've explained in previous threads that receiver stock isn't a common thing in steel yards. No steel yard locally has it in stock. The 2 in sq tube for the drawbars, yes they have that, and I have most of a 20' stick of that out in the shop. Proper receiver stock has a .238 wall/rounded corners and is flash removed on the inside.
    Steel Flash Removed Square Tube 2-1/2 x 2-1/2 x .238 (Grade A500) | Buy Small Quantities Online | Allmetalsinc.com
  8. #18
    Join Date
    Dec 2008
    Posts
    898
    Buffalo, New York
    318 John Deere, 4200 John Deere, 1947 John Deere "M"
    Metal Supermarket has it, and it's called 'Trailer Structural'. Just don't know where you are! I've got one about two blocks away, and it's like a "Big boy, DIY, Candy store". ~Scotty
    Metal Supermarkets
  9. #19
    Join Date
    Jul 2007
    Posts
    2,718
    SC/NC
    They opened a store in Columbia, SC recently so I'll have to go check them out.
  10. #20
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,682
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    I had a similar problem with the cheapie HF receivers, but this was due to the seam on the inside of the tube. Took a big, long flat file and worked on it until the drawbar went in.
    Runner
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
