6sunset6
- Joined
- May 6, 2007
- Messages
- 1,056
- Location
- SE NY
- Tractor
- NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
Another post on a log splitter.
I have a 4 x 24 cylinder splitter. I converted the gas engine to an electric motor 1.5 hp face mounted 11 gpm Barnes 2 stage pump 3600 rpm 220v.
Works great single wedge . low tires so the beam is about 8 inches off the ground. The top of the beam. I have split 20" diameter ash with no problem. I am short so bending does not bother me much. But lifting 20" sections even 8 inches and then repositioning the chunks is something else.
I have coming up 4 white oaks 24" plus. I am not looking foward to handling those chunks with my current spitter set up. I had so many choices I had to do an economic weighted analysis to figuire out what to do. See the attachment. I do this sometimes when there are so many options it gets hard to see straight. The first column sort of compares each feature in each option. Say time to aquire if I buy it time is zero so the value is 10 but If I build it the value is something less depending on how long to build or how complicated. But that's not the whole story. Another weighting feature is how important that option is. Thats the X col. Of course you can fiddle with the numbers to make it come out anyway you want. You can see with out maintaining another engine the new spitter is the best option. When I fold in maintaining another engine then adding a log lifter to my current splitter is best. The reason the the cost is so low for that is I have all the partds around. It is an interesting approach to decision making.Makes me feel like I applied some thought to what I am going to do.
All that said I still have not decided. Was this understandable?
Sorry .xls will not upload and .pdf is 2 pages hard to read .zip did not work either.
