Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 60
  1. #21
    New Member
    Join Date
    Oct 2007
    Posts
    22
    Runaway Bay, TX-wise county
    jd 855/FEL
    Default Re: Any Homemade Mini Dozers?
    My brother has one of the Strunk dozers. He is disabled and not using it anymore, but it actually did some real work when he was using it
  2. #22
    Join Date
    Nov 2008
    Posts
    849
    Brampton, On\lot Powassan, ON Canada
    Kubota B4200\MF 135\Kubota B3200
    This is one of my favorites. It seems to be powerful and fast. Several U-tube videos
    YouTube - Aurausta tela-ajoneuvolla 2
    Unimogdave
  3. #23
    Join Date
    Nov 2008
    Posts
    849
    I made chain tracks for this project. As it was made for the snow, steering was not an issue. On dirt its hard to steer with a load of wood. I made the front axle adjustible in order to tension the track. I would in future allow the track to wrap a little more around the tires as it will throw a track from time to time.
    YouTube - Powered Wheelbarrow
    Unimogdave
  4. #24
    Gold Member
    Join Date
    Jan 2007
    Posts
    383
    Athol ID.
    Kubota L-35
    Quote Originally Posted by David Devuono View Post
    Love the sound of that turbo diesel!
    Looked like a lot of fun sliding around in the snow, corse if he had taken the side off that red car it wouldent have been so cool!
    Did you notice it had a steering wheel? Wonder how that is set up?
  5. #25
    Join Date
    Mar 2008
    Posts
    87
    the steering wheel probly just controls the valves that stop/start/reveirse the drive motor
  6. #26
    Join Date
    Mar 2009
    Posts
    85
    Vermont
    Cub Cadet 1512
    I have been slowly collecting parts to build a mini dozer for myself. More of a rider mower scale so not a large as the one you are describing. Tracks length on the ground will be around 4.5 ft. I had a question for J J on that at Zturn pump/control (Kanaski DUP7a) from surplus center. Do those calculations account for the double pump? The flow is 6 gpm @1450 psi for each pump.
    Just trying to figure it out which way I will go. I have one of those pumps sitting on my bench right now and I may us it for the dozer project or something else.
    I am having a little trouble finding a pulley to fit the tapered metric shaft of the pump so any ideas would be great. Right now my only option is a new pulley off a john deere zturn which uses a Kanaski DUP10 pump. Looks like the shaft is the same size.
    Thanks
  7. #27
    Elite Member
    Join Date
    Mar 2002
    Posts
    2,898
    Iuka Mississippi USA
    3550 Fard Backhoe and a 1948 Farmall Cub,
    Remember when they changed the co host on Junkyard wars from That rogers lady, She went to a similar show called Full Metal Challenge. Teams brought in alot of homebuiult machinery to race each other in events. Remeber the team that got all the way to the finals to have a transmission problem It was a couple canadian kids that worked in a machine shop. They had i think a 500 CI Caddy motor. the sproket was flame cut and the tracks were thick conveyor belts split and they had 2 inch channel bolted to the them with carriage bolts. I cant think of the guids o nthe inside of the track other than the offset i nthe meta from the channels. It used a 3/4 or 1 ton floating rear end to make it steer. I wished I could have remebered the name of it. It had a cseveral axles on the bottom for bogeys. The tracks looked alot like the ones used on snow tractor conversions.
  8. #28
    Super Member Iplayfarmer's Avatar
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Massey Ferguson 1215, Toro 266-H, Farmall Cub, Farmall A
    Quote Originally Posted by simplicityguy92 View Post
    I've dabbled with the idea of a yoke or a stearing wheel...trying to make it easier for the kids to operate. It would be set up something like a joystick that controls both valves. The best I've come up with so far is something like the setup in a swather. You have a wheel that also pushes forward and back. With the wheel in a neutral position you could turn it one way or the other without pushing forward or back and you'd go into a zero radius turn.
    From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
  9. #29
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Qorkinprogress,
    All I saw was total cu in, and GPM. It could be like you said. I would call Burden and ask their hydraulic guy.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  10. #30
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    The first Struck Magnatracks used belts for fwd and rev , and used brakes to steer. The next generation, used a 4 speed peerless transmission and chains to drive, and brakes to steer. The latest generation of the Magnatracks uses hydraulics to drive and steer. In building something similar to the Magnatracks, you have to consider the HP of the motor, and how much pump can the motor run. Then you have to match up hydraulic wheel motors if you go that route. In considering the motors, you have to know how much weight the motor will have to push to drive, and if you push dirt with it, you will need a larger hydraulic motor. If using the Peerless 4 spd transmission, with sprockets where the wheels would normally bolt on, you then drive the tracks with heavy duty chain, going from say a sprocket of ten teeth to a sprocket of fifty teeth, which will turn the tracks. You can get tracks from many different manufactures, or make your own. As I said before, if I put my Magnatracks in low gear, it just slowly crawls along. I also have a dozer blade and a bucket for mine, and uses electric motors to raise and lower the bucket. My Magnatrack also has a 16 HP Wisconsin engine, with electric start.
    J.J.
    Git er done.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
