Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    New Member
    Join Date
    Jan 2008
    Posts
    22
    Oklahoma
    2002 NH TC40DA 1974 IH 474
    Default Homemade post hole digger
    Heres a post hole auger I built, The tube is 2 7/8 pipe. I bought the gear box on e bay for 100 with shipping and also the auger for about a 100 with shipping. I had the driveline already I got about another 50 in odds and ends as well as gas and rods. 250 total. It works pretty good, although the tip on the auger is kinda cheap, I've alreay bought a heavier tip from TSC. The auger is a leinbach. If you count my labor I probably have way more in it but it was fun to build. I measured a buddy's speeco and made this pretty close demension wise. I had a heavy top link with a damaged end I added to the top for adjustment. Probably won't need to adjust it but the broke top link found a home anyway.
    Attached Thumbnails Attached Thumbnails Homemade post hole digger-phd-jpg   Homemade post hole digger-phd2-jpg   Homemade post hole digger-phd3-jpg
  2. #2
    Elite Member Ductape's Avatar
    Join Date
    Feb 2006
    Posts
    4,856
    Central New Hampshire
    Kubota B3030HSDC
    Default Re: Homemade post hole digger
    Nice work ! As long as I've been hanging out here on TBN...... this is the first home built PHD I can recall anyone making.
  3. #3
    Gold Member digger2's Avatar
    Join Date
    Dec 2006
    Posts
    268
    n.e. pa.(lycoming co.)
    kubota B26 TLB,former B7610 owner
    Redneck,nice job........can i ask what ratio your gearbox is?Just in case i ever decide to build one.
    Digger2
    Kubota B26 TLB
    Ex Wives.....Ahhhh,the memories
  4. #4
    New Member
    Join Date
    Jan 2008
    Posts
    22
    Oklahoma
    You know I never did check the ratio. The gearbox is factory made for PHD's.
    The seller said he made a special purchase of a lot of these that had a seal problem, he will warranty it for a year as long as you keep oil in it and address the seal problem. The problem with seal was the OD bore was slightly large I removed the seal and put it back with 3m weatherstrip adhesive. Filled it up with oil over a month ago and not even a drip yet.
  5. #5
    New Member
    Join Date
    Jan 2008
    Posts
    22
    Oklahoma
    In fact I just checked e bay, the seller still has them for sale. 65 plus shipping. It shows he has only sold one. I guess I was the only one willing to take a chance. Everything on it seems good and heavy just the bottom seal was a little loose. I know I'm not supposed to put e bay links here but you can find by searching "post gear box"
  6. #6
    Join Date
    Apr 2007
    Posts
    218
    NW Georgia
    1964 Ford 2000D and 1959 Ford 801
    Nice job. I might start a war here, but i really like the color.
  7. #7
    New Member
    Join Date
    Jan 2008
    Posts
    22
    Oklahoma
    Its behind a TC40 NH , so I thought Ford blue was fitting. But I'm definatley on the Blue side anyway. From Trucks to tractors. Attatched you will see my craftsman that got a Blue makeover.
    Attached Thumbnails Attached Thumbnails Homemade post hole digger-ford1-jpg   Homemade post hole digger-ford-jpg
  8. #8
    Join Date
    Mar 2008
    Posts
    87
    nice phd
  9. #9
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Nice build. I have a home made one that was built using a 9" Ford rear end. Its got a 3.73 gear ratio. Just took out one of the axles and welded a plate over it for the top end of the gear box. Used the other axle on a shortened tube to attach the auger.
    Chris
  10. #10
    Silver Member emmy71's Avatar
    Join Date
    Nov 2005
    Posts
    222
    North Carolina Piedmont
    Kubota L3400 HST
    Quote Originally Posted by Diamondpilot View Post
    Chris
    Same here. Mine works great. Got it with a 9" auger for $100.00.
    Terry
    2006 Kubota L3400 HST, R4's, LA 463 loader.
    Landpride FDR1672 mower, Hawkline 5' rotary cutter, 5' United boxblade, 6' scrape blade, Woods 5000 chipper/shredder
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
