Results 1 to 10 of 26
05-01-2009, 05:42 AM #1Silver Member
- Join Date
- Feb 2004
- Posts
- 225
- Location
- Ireland
- Tractor
- Fiat 82-94
Tyre Mats
Hi all,
Im looking into making tyre mats for my neighbours farm. Here is a link to what I am talking about
Unique Inventions Company Ltd, Ballyragget,Kilkenny, supplying labour saving devices for common farmyard and garden chores.
Each tyre mat consists of 45 fasteners and I believe the silage pit will require over 20 mats. If I can make this process fast and easy I will be able to do this job at home and maybe for a few more farmers if the idea works. Taking the tyres off a pit on a cold rainy day in Ireland is no fun so this eliminates getting soaked from the water built up inside the tyres, the possibility of getting infected by vermin urine and the dangers of wires sticking out of badly worn tyres. Id appreciate any suggestions people may have.
What Ive done so far:
I started out looking at drilling holes in the tyres with a hole saw which worked but it was slow and the wire in the tyre still remained in place which made pushing bolts through difficult. From there my idea moved to punching each tyre with a punch and press. It was then myself and a few colleagues thought of completely eliminating any drilling/punching process. We came up with the idea of pushing the bolt through the tyre like a nail. I machined up a small sleeve with an 8mm internal diameter so that the bolt slid up inside it. The tip was sharpened to 45 degrees (test angle). I made the following rig using some scrap steel and an old hydraulic bottle jack. I tried initially to push the bolt+sleeve through two tyres and found that the tip of the sleeve was not sharp enough to pierce the inside of the tyre. I tested pushing through a tyre starting on the outside and the bolt got pushed through as it got a good grip in the rubber. Therefore with some tuning I think this idea may work. My own thoughts is to make either a lever operated mechanism (bottle jack is a bit slow and to retract it its quite tricky) or use a spring returned single acting air cylinder on a similar rig.
Best Regards,
RonanThe man who never made a mistake never made anything
05-01-2009, 06:29 AM #2
Re: Tyre Mats
That is a good idea. I was thinking of doing somewhat similar only two tires wide to make a road out into one of our swamps and building a little Gazebo on stilts for wildlife watching. Nothing has ever happened on this as the environment police would frown on such use of tires.
It sounds like you need a hydraulically operated hole punch of proper dimension and strength. Lay a tire on it , punch a hole, turn tire and punch another hole and so forth. The hydraulics should be faster than a bottle jack. Something like the setup for wood splitter. Keep the fixed portion of the punch inside the tire and have the hydraulic systems set up on the outside?? Have the tire set on a rotating plate that has stops at 90 degrees so the holes get punched on a very regular angular basis. No random holes off a few degrees.
Looking at Industrial punches may give you better ideas!
Apply for Government grants to get a small business going?Egon
50 years behind the times
Livin in a
Worn out skin bag filled with rattlin bones
05-01-2009, 07:37 AM #3Veteran Member
- Join Date
- Jul 2005
- Posts
- 1,317
- Location
- W.Mass
- Tractor
- 1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
Re: Tyre Mats
Egon is onto something. Do you want to drill and bolt the tires as you go, or predrill/prepare a bunch of tires first then bolt them together? It must matter what size the tire is also as to whether they'd align with each other.
I keep thinking a self-drilling fastener would be quicker than a punch, and allow you to assemble as you go. In building we use air-drive fasteners a lot - maybe there's something along that line that's strong enough?
I imagine you're talking about moving the assembled mats with a loader or drag them with a tractor? You mentioned you'd do this job at home - how do you move the finished mat to the farm?
I agree about the rain water, etc. It's a sloppy job to move them.
Jim"Anything worth doing is worth doing slowly" Mae West
05-01-2009, 08:25 AM #4Silver Member
- Join Date
- Feb 2004
- Posts
- 225
- Location
- Ireland
- Tractor
- Fiat 82-94
Re: Tyre Mats
Thanks Guys,
I am looking for a method that I can do on site. The mats would be too big to transport from my house. Sorry by at home I meant next door on the farm.. These mats would be lifted off one row at a time to allow the plastic covers to be pulled back. I was concentrating my efforts on M8 bolts with fender washers. Is there anything like a TEK screw that would be capable of holding a mat of tyres together. When being lifted the entire weight of 26 tyres will be hanging off 2-4 bolts. That is why I was pursuing with bolts. My whole idea is to minimise the amount of tasks needed and time required. So to eliminate the need to pre drill/punch is my goal. I want to be able to shoot the bolt (with the pointed sleeve) through the two tyres, remove the pointed sleeve and put a washer and nut. then just tighten the nuts. So for two people, 28 tyres would be laid out. 1 person would use the mechanism to insert the bolts and the other follow and tighten the nuts. The goal would be to be able to make 20 of these in one day for the average pit. Just a little side earner for a few weeks. I am probably a little late for this year as the grass is due to be cut in the next 3-6 weeks but I suppose if I developed a good working model I could start bolting the tyres that are coming off the pit in the spring next year. Each mat would have to consist of tyres that are similar in size. All R13s together, all r 14s together...
Thanks,
05-01-2009, 05:28 PM #5
Re: Tyre Mats
Nothing saying you can't prepunch the tires at one location and move them to the assembly area.
Cables run through the sidewalls? They would puncture easily.
Egon
Livin in a
05-16-2009, 05:03 PM #6New Member
- Join Date
- May 2009
- Posts
- 1
Re: Tyre Mats
You may be trying to make this harder than it has to be. You can get machine thread screws which already have a drill point on them. Over on this side of the pond, I found the following screws:
3/8-16 X 1 1/4 Type 1 TCS / Unslotted / Hex Head / Steel / Zinc - Fastener SuperStore, Inc.
Put a washer on the screw, drill it through the tires, put a washer and nut on the other side, and draw them up with the drill motor. You could probably do 26 tires in 30 minutes once you got the rhythm going.
Just a thought,
Dr. Spiff
05-16-2009, 05:21 PM #7Super Member
- Join Date
- Feb 2006
- Posts
- 6,773
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Re: Tyre Mats
Those arent drill points. Theyre thread cutting/cleaning screws. I imagine drill points are even more expensive.
larryThis side of 40
JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
IH37 Baler, Hesston Haybine, JD Rake
Bushog, Flail,
SK Tilt Tatch
, KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
05-16-2009, 08:32 PM #8Veteran Member
- Join Date
- Jul 2005
- Posts
- 1,924
- Location
- NH seacoast & Coos County
- Tractor
- Kioti DK45S
Re: Tyre Mats
Rgillard, Consider developing a way to cut the tires in half around the center of the tread. You get both halves to work with. Each half is easier to handle when punching holes - make a freestanding punch hydraulically powered with small electric snowplow or power steering pump. You can use a big ram cause it only has to move 1". Cut & punched tires stack togeather better for shipping which may lend it's self to your selling them kit style. i.e. a Pile of tire halves & a bag of bolts on a pallet. Assembly is lighter & thinner making it easier to handle & takes less room to store. The assembly made from 1/2 tire "cups" also makes a great land smoothing device behind a harrow. Best reason for cutting - when assembled they don't hold water.
Also if you develop a good way to cut the tires you may have other options to sell the cutting service -i.e. cut tires are allowed in many landfills. This sounds anti-green but there's tons more recycled rubber already than there's any market for.
Do a search for "hydraulic hole press" and you'll find C frame presses & dies that will pierce up to 1/2 steel that will punch your tires. MikeD74TLast edited by MikeD74T; 05-16-2009 at 08:50 PM.
05-16-2009, 09:13 PM #9
Re: Tyre Mats
Is it possible to use lengths of galvanized cable or fencing wire threaded from side to side and top to bottom of the 'mat'? Then all you would need to do is thread the cable through holes drilled in the tyres. Might even be cheaper than bolts.
01-13-2010, 07:00 AM #10Silver Member
- Join Date
- Feb 2004
- Posts
- 225
- Location
- Ireland
- Tractor
- Fiat 82-94
Re: Tyre Mats
Hi Guys,
Is there anything commercially available like this? It would let me do this job very quickly and prevent me having to screw on washers etc. I have done extensive searching on the net and not had much joy. I did find a few plastic versions but I would doubt that they would be up to this task. Any info is muchly appreciated...
Regards,
RonanLast edited by Rgillard; 01-13-2010 at 07:02 AM. Reason: pictures not attached
