Results 1 to 10 of 50
05-07-2009, 07:06 AM #1New Member
- Join Date
- May 2009
- Posts
- 10
- Location
- douglas, ma
- Tractor
- my back
Splitter wedge mount location on log splitter-
Hi guys!
I built myself a nice log splitter- I was wondering what the pro's & con's are to mounting the wedge on the cylinder, instead of welding it to the i-beam. Anyone have any thoughts on this or experience in which works better?
05-07-2009 07:06 AM # ADS
05-07-2009, 07:10 AM #2New Member
- Join Date
- May 2009
- Posts
- 10
- Location
- douglas, ma
- Tractor
- my back
Re: Splitter wedge mount location on log splitter-
couple more pics- I bought a new cylinder and was going to mount the wedge to the cylinder... I've seen it done both ways, wasn't sure if one is favored over the other...
05-07-2009, 07:27 AM #3Veteran Member
- Join Date
- Sep 2005
- Posts
- 1,193
- Location
- Ohio
- Tractor
- Case DX55, Ford 850
I've used both, and like the wedge mounted on the cylinder much better. With it on the cylider the logs split right in front of you. With the wedge on the beam, the logs are pushed past the platform with each stroke and you are twisting and relocating the logs for additional splits. My back is thankful for the wedge on cylinder design.
05-07-2009, 08:11 AM #4New Member
- Join Date
- May 2009
- Posts
- 10
- Location
- douglas, ma
- Tractor
- my back
ford850- I never even thought of that aspect! you're absolutly right! I'm always bending over to pick up the wood that gets pushed through the fixed wedge to relocate it, If I put the wedge on the cylinder, and weld a small table to the side, the wood will split in front of me and fall onto the table, then I can just throw it where I want to- no more bending over!
Big help, thanks!
05-07-2009, 08:30 AM #5Veteran Member
- Join Date
- Feb 2008
- Posts
- 1,723
- Location
- "Ranchin'" on a 1/4 of a 1/4 in Seminole County, Oklahoma!
- Tractor
- 2004 Kubota M4800 SU
Beergut, either way you've got a good looking splitter! Nice work.
JayJay
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
If My people who are called by My name will humble themselves, and pray and seek My face, and turn from their wicked ways, then I will hear from heaven, and will forgive their sin and heal their land. 2 Chronicles 7:14 NKJV
05-07-2009, 08:55 AM #6New Member
- Join Date
- May 2009
- Posts
- 10
- Location
- douglas, ma
- Tractor
- my back
Thanks jayste!
The 3.5" cylinder (2.5 x 14 rod 3000psi) & spool valve I took off an old fork truck,
the 8 hp motor (with electric start!) came off an old snow blower my neighbor was throwing away (engine was in excellent shape).
The beam came from a scrap yard for $20-
I bought the pump (haldex 13.6 gpm 3000 psi) & fluid tank from NT- and the current wedge I made myself from 1" stock.
It's all glued together by my humble but mighty little Hobart 210 Mig (which I love)
I just bought a new 12" wedge from NT, which I plan, after much thought, on welding to the cylinder.
A lot of people comment on the small area to split wood- it'll only take about 18", but my stove only takes 16", so it's perfect for me.
I have about $300 into this splitter not too bad considering
oh- and the tires & fenders came off an old yerf dog go kart-Last edited by beergut; 05-07-2009 at 09:10 AM.
05-07-2009, 09:04 AM #7
The advantage to the wedge on the beam is you can put a tray after the wedge for the bigger ones that need re-split, and the ones that don't need re-split, you can just keep pushing and you don't have to worry about having to keep moving split pecies out of the way.
The only advantage to the wedge on the cylinder is the ability to split wood in the vertical position. All the splitters you can buy that are horizontal only have the wedge on the beam. All the ones that are vertical capable have the wedge on the cyl.
Having a hor/vert myself, when splitting in the horizontal position, I would rather have the wedge on the beam, but then it wouldn't do vertical.".........there is only one way to find out."
"Ok, hold my beer and watch this.........."
Ford 5500 Backhoe
Kubota L3400GST W/LA463 FEL
2005 Dodge 3500 4x4 Diesel
8N Rebuilt and restored
Bushhog 105 and 306 cutters
JD 261 3PH mower
3 Homemade wood hauling trailers
Dolmar 7900
Dolmar 6400 84cc ported BB kit and Muffler Modded
Sachs-Dolmar 120SI Ported
(4) Sachs-Dolmar 116SI Ported
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
05-07-2009, 06:33 PM #8
Wedge on the beam is my choice.The wood comes off the end of the splitter,and not at my feet.With the trailer hitch on the opposite end of the wedge ,i simply move ahead a bit if wood builds up at the end of the splitter.Ican worry about getting the next log ,while its returning and not have to throw the splits out of the way.my 2 cents
alanKUBOTA BX-23,Block heater, AG TIRES[rears filled],MECHANICAL THUMB,SALSCO CHIPPER,WOODS LRC60 LANDSCAPE RAKE WITH GAUGE WHEELS,,HOMEMADE BUCKET FORKS,QUICK HITCH FOR 3 POINT HITCH,HOMEMADE FRONT BUCKET MOUNTED QUICK HITCH[for 3 point implements], FARM FORCE 6 FT 3 POINT BLADE,MARKHAM TOOTHBAR,HOMEMADE TRAILER HITCH FOR BACKHOE, HOMEMADE HEATED STEEL AND FIBERGLASS CAB,54 INCH PRONOVOST PUMA 3 POINT SNOW BLOWER,WITH HYDRAULIC CHUTE CONTROL,REAR TIRE CHAINS,UPGRADED 40 AMP ALTERNATOR,4-55W LIGHTS
05-07-2009, 07:03 PM #9New Member
- Join Date
- May 2009
- Posts
- 10
- Location
- douglas, ma
- Tractor
- my back
You guys make some good points- Though, when I think back to when I split wood, I do spend a lot of time moving the wood from around the wedge (welded to the end of the beam) and throwing it out of the way. Since the splitter is already quite low, the wood piles up pretty fast. I'm always bent over. But, if I put the wedge on the cylinder, I can immediately toss it aside without ever bending over. So, I'm going to weld it onto the cylinder for now. What the ****- if I don't like it, I'll grab the OA torches and put the wedge back on the beam...
05-07-2009, 07:16 PM #10
I have used both. I like the one with wedge on the cylinder. When you encounter a piece you couldnt split or gets stuck, just return it since there is a push off arms o more whacking at the chuck that wouldn't split. This is more important on the lower tonnage splitters then the ones at 30 or higher.
