Spencer
- Joined
- Jan 2, 2002
- Messages
- 1,270
- Location
- Western Michigan
- Tractor
- NH TC33D w/R4 Tires, Rear Remote, Hydraulic Toplink, 2 Auxiliary Work Lights, 7308 Loader w/Kasco Uni-Hitch (Quick Tach)
I started working on my first project tonight. After seeing Jim Gerken's nice personnel lift and after reading numerous posts by Wroughtn_Harv I decided it was time for me to make my own personnel lift. I plan on building my pole barn this summer and even though I have two sets of nice scaffolding I thought a personnel lift on the tractor would be nice to have. I don't plan on putting in any cement until the pole barn is up so the standard scaffolding would be a major pain to use in the sand.
I have a Kasco Quick-Tach adapter Forks, and my <A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/5-145669-Switch_Hitch.jpg>Switch-Hitch</A>. I would prefer to make the personnel lift hook right up the Uni-Hitch but after calling my dealer I decided not to go that route. The cheapest set of Quick-Tach plates he could get were $119 and that is just about the same price I paid for all the material I bought to make this whole project. I decided to have the personnel lift hook up to the Switch-Hitch's 2" receiver. It seemed the most economical and reasonable choice.
The lift will be 30" by 60" and have two levels. The lower level will be for holding my smaller generator for those projects where I will need 120 volt power. The other purpose for the lower level is to get the upper level higher and make the safety rail more rigid. My FEL will only lift to about 8 feet at the pivot and I wanted my feet to be higher than that. So I will make the lower level 30" high and then have a 42" safety rail on the upper level making the whole structure 6 feet high.
