HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-16-2009, 09:29 PM   #1 (permalink)
Default Completed Grapple
Folks I have completed the grapple for my Kubota L4310 - I used mostly 2nd hand steel - 2x3 1/4 inch square tubing and grade 10 walkway grates for the brush guard on the grill and the grapple. Over all I would suggest anyone looking for a 3rd function kit get the WR Long kit - it sets up wonderfully and the thumb switch on the loader control makes it seem to easy.
I would like to thank Kennyd along with Dave and Jason for the input they had on this project - also the TBN'er whom stuck a limb through his JD - as I used that picture for the justification to go with the heavy guards on the grapple and grill.
The cylinder placement is in the center with no clearance issues - I would never consider placing the cylinder on the top - I am sure that the pictures from the ANBO grapples had a lot to do with my design.
The grapple is 57 wide with a 30 inch back and a three top clamp run by one 4 inch cylinder with a 2 inch bore - it came with a scrap loader I tore apart.
Costs WR Long Kit 580.00 - Steel - 220.00 - Supplies - 200.00 - Scrap Loader 160.00 - Other - 100.00
Total 1260.00 - Built and designed.
completed-grapple-grapple-scrap.jpg  completed-grapple-img_2866.jpg  completed-grapple-img_2867.jpg  completed-grapple-img_2865.jpg
__________________
"a country boy can survive"
Kubota L4310 HST 4x4 w/ LA681 FEL and Shop Built Brush Grapple.
Attachments Woods HB 84 Box Blade, Woods LR 72 Landscape Rake, Rhino SE 6 Brushcutter, Rhino HPHD Post Hole Digger and a Shop Built Soil Packer.
SouthernConservative is offline   Reply With Quote
Old 06-16-2009, 10:30 PM   #2 (permalink)
Super Member
kennyd's Avatar
Default Re: Completed Grapple
Very nice
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
JD 4x2 Turf Gator
Some of my projects/adventures are posted in my Picassa Web album.
kennyd is offline   Reply With Quote
Old 06-17-2009, 08:18 PM   #3 (permalink)
Elite Member
Ductape's Avatar
I'm pretty sure that sucker would eat my tractor whole !
Ductape is offline   Reply With Quote
Old 06-17-2009, 09:38 PM   #4 (permalink)
gerard's Avatar
Very nice work. Hope you have an awful lot of brush to move cause it won't take very long with that set up!!
__________________
Experience is something you get right after you need it!
Kubota L2500 DT w/ 5 foot FEL and Pat's easy change system
5ft box blade, 5ft bushhog, 6ft york rake w/ guage wheels, 7ft backblade w/skid shoes , post hole digger, 5 foot snowblower, dual axel 16 foot landscape trailer, 330 gal water tank, Ford 250 diesel, 6 wheel drive polaris ranger
gerard is offline   Reply With Quote
Old 06-17-2009, 10:51 PM   #5 (permalink)
Nice grapple SC. Youll find it super handy on your tractor. Ive built many for smaller tractors and loaders, and run several on larger loaders building roads. They sure make it alot more enjoyable than trying to balance it on forks or chain it to the bucket. Also you can yous it to accumulate several mini brush piles into one load if you line your windrows up right. I got a question is that a rock piccker bucket you have on the scrap loader. I have a fella wanting me to build him something similar if it is. Take care TL.
Taylortractornut is offline   Reply With Quote
Old 06-18-2009, 01:50 AM   #6 (permalink)
MJPetersen's Avatar
Send a message via Skype™ to MJPetersen
That should "eat" your brush piles in a hurry. I like the way that it opens up so wide.
I was wondering though, I would think that you should weld covers on the tubing on the grapples and the forks or they would pack full of dirt, debris in a big hurry and promote rust.
Mike
__________________
"In all your ways acknowledge Him and He will direct your paths." Solomon
YM1510D, YM 1202 tiller, The following home made tools: Quick Hitch, KK copy dirt scoop, imitation Gannon rollover box blade, Forks on 3pt, and a Rear Blade with gauge wheels
MJPetersen is offline   Reply With Quote
Old 06-18-2009, 08:34 AM   #7 (permalink)
Banned
Very nice job & it looks very strong built!!
johndeere4300 is offline   Reply With Quote
Old 06-18-2009, 08:55 AM   #8 (permalink)
J_J
Super Member
J_J's Avatar
Nice work, I am curious why you did not put a taper on the front of the box tubing. You could however put a solid extension inside the tubes for more strength,
__________________
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done, if-fen you want to..
J_J is offline   Reply With Quote
Old 06-18-2009, 09:32 AM   #9 (permalink)
I left the ends open so that when I choose I can insert steel pipe in the two ends (four total) and move lumber and other supplies that are wider that the bottom 24 inch teeth - I may close them up if they become a dirt haven.
The rock bucket was used on a county truck to clear roads of gravel - I have since cut up the bucket to use for brackets on another project.
The grapple is making money for me already - yesterday I have cleaned up a debris pile that was on the property when I moved here ... and with the help of the grapple gathered and sold 3600 lbs of junk - at the cost of $4.00 per hundred pounds - I am now ready to start on the brush piles that I created with a JD 555 Crawler.
Thanks for the comments - I hope to get a MIG welder and be able to weld better and faster...only this would lead to more projects.
__________________
Old 06-19-2009, 03:18 AM   #10 (permalink)
2310 guy's Avatar
Thats well done
2310 guy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.24934 seconds with 9 queries
