Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Jun 2003
    Posts
    65
    North Cen. Mo.
    JD2305 JD5205
    Default Prototype sod cutter
    Hopefully these pics will post for me. This is only a prototype. The next one will be made as one detachable assembly.
    Attached Thumbnails Attached Thumbnails Prototype sod cutter-100_4287-jpg   Prototype sod cutter-100_4291-jpg   Prototype sod cutter-100_4292-jpg   Prototype sod cutter-img00111-jpg
    JD5205 MFWD
    520 FEL
    LX6 RC
    Other stuff
  2. #2
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Default Re: Prototype sod cutter
    Awesome idea.
    ::Sent from a standard desktop keyboard::
    My Photobucket
  3. #3
    Veteran Member have_blue's Avatar
    Join Date
    Oct 2003
    Posts
    1,730
    Eunice, Louisiana
    L4400
    Sprocket,
    Appears to work great!
    Bob
    From the heart of Cajun Country
  4. #4
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,682
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    Outstanding work!
    I need one of those for an upcoming yard project, but probably couldn't get it fabbed up soon enough.
    Nice, simple, effective design.
    Thanks for posting.
    Runner
  5. #5
    Join Date
    Jun 2003
    Posts
    65
    North Cen. Mo.
    JD2305 JD5205
    Thanks for the compliments. I hope someone sees the pics and improves on the theory. I am open to suggestions. It occured to me that it would mount on a bucket just as easily as forks. The discs are salvaged from my son-in-laws grain drill. I think new cost is around $20 per blade. He replaced all 46 blades. Needless to say I have a bunch of spares. Maybe I can find a use for some of them on other projects.
    My intention was to roll up the sod with my big tractor and dump the roll into my loader bucket on my 2305. It would be able to get into tighter places.
    If anyone builds a sod cutter similar to this be sure and remember that cut sod gets really heavy quickly. It doesn' take very many square feet to weigh a bunch.
    Thanks again.
    BTW, if you leave the curved bars off the cut sod will actually slide over the back of the fork frame and lay back down in the trench. One might be able to pick sections of sod up with a regular loader bucket.
    JD5205 MFWD
    520 FEL
    LX6 RC
    Other stuff
  6. #6
    Platinum Member mcd176's Avatar
    Join Date
    Nov 2007
    Posts
    500
    Wheeling, WV
    Kubota M6800HD / Kubota B2150
    Nice design work, you could make some money!
    Kubota B2150
    Link to my custom cab: http://www.tractorbynet.com/forums/b...completed.html
  7. #7
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    nice idea! sometimes the best working implements has fewest parts but heavy duty moving parts that lasts and lasts. I can envision having hydralics to push the sod off, a cutter to cut the sod when finished cutting a roll. I have a question though- can you acutally see whats happening from your seat, but just see the top of the rolling sod ?
  8. #8
    Join Date
    Jun 2003
    Posts
    65
    North Cen. Mo.
    JD2305 JD5205
    Thanks. It is a little hard to see. I have to lean over slightly. Ground speed is very slow so it is really not a problem. I think my 2305 would be able to handle this contraption with no strain. That would make visibility better.
    One could keep adding options to make this work even better. Fun project to think about and fabrication costs shouldn't be much.
    JD5205 MFWD
    520 FEL
    LX6 RC
    Other stuff
  9. #9
    Platinum Member myyaz33's Avatar
    Join Date
    Aug 2006
    Posts
    733
    Nebraska
    TYM T273
    Quote Originally Posted by Sprocket1 View Post
    It appears you are taking more soil than necessary if the use is intended for normal sod harvesting. If you have it set for that depth for another reason such as cutting a flower bed then it may make sense.
    Oh yeah what very slick idea!
    - TYM T273, BT200 Backhoe, LT200 Quick Attach FEL-
  10. #10
    Join Date
    Jun 2003
    Posts
    65
    North Cen. Mo.
    JD2305 JD5205
    I yanked out some big shrubs in front of my mothers house. I needed to add dirt to bring the sod level up to the height of a short retaining wall. It was easier to leave the dirt on the sod rather than haul in and level more loose dirt.
    I also wanted to assure that the sod would live. I mowed it before cutting. That was last week. Durn stuff needs mowing already.
    Because it is a prototype I didn't slot the mounting holes to adjust the thickness, but you are right. I took more dirt than necessary.
    JD5205 MFWD
    520 FEL
    LX6 RC
    Other stuff
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
