chim
Elite Member
...............If anyone has an L 30 series tractor with a coolant heater, I would really like to see how you plumbed it. Thanks
Here you go. My connection is at the bypass on the top of the engine. The hose marked "A" is a short 90 degree factory-installed hose. The top end was connected to where the "B" hose is now hooked into. The 90 degree hose is roughly 1/2" at the bottom and 5/8" at the top. Spinning it around allowed a coupling to be used for the one heater hose and have the size match. The "B" hose runs to the other side of the heater. It is valved in an H pattern that allows the coolant to either flow through the heater core or bypass it. There needs to be a path for flow of the coolant because the plumbing is in the bypass. The heater I used is a 20,000 BUT and is capable of providing too much heat on HI.
