Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Gold Member Localmotion's Avatar
    Join Date
    Jun 2009
    Posts
    439
    Spain
    New Holland 50-86 / Siromer 204S / Case CK-28 / Cat 302.5 / Nissan L35.09 / Nissan Atleon 110
    Default Re: Anyone Ever Built a Manure Spreader?
    I've been looking through some old threads to see about building a simple muck spreader (simialr situation to OP).
    Just wondering if there have been any new ideas or muck spreader built since the last post?
    Some plans would be great...
    Check out our website: http://localmotion-spain.co.uk
  2. #22
    Bronze Member massy1635's Avatar
    Join Date
    Apr 2010
    Posts
    63
    Central Maine
    Massey Ferguson 1635 with a factory cab and HEAT
    I would like to build a side slinger spreader. What I want it for is to grind up the end of the season left over plant material from our greenhouses and field growing. The root balls and stems are hard to deal with. If I could pulverize this stuff then I could spread it on my fields.
    There is no $50 job I can't do without $100 worth of new tools.
  3. #23
    Join Date
    Jun 2009
    Posts
    439
    Spain
    Quote Originally Posted by massy1635 View Post
    I've also considered a side discharge (like the photo, not the chain type), and wondered if an old chipper could be converted? I thought maybe it could be adapted with a large vertical hopper to hold the waste, feeding into the chopper unit, with the discharge tube angled 45 degrees to the side? The only problem I can forsee, is that the cost of buying and adapting an old chipper would probably cost more than a cheap spreader (which is already more than I want to pay)!!!
    Anyone Ever Built a Manure Spreader?-2_432_e-jpg
  4. #24
    Join Date
    Dec 2009
    Posts
    99
    Bellingham, Washington
    Kubota B7100, IH B275
    Instead of using a chipper, use a crop chopper... also known as a silage chopper. You can pick up an old one for scrap price. They they consist of a flail mower, cross-feed auger, and a large flywheel chipper/blower. You could pretty much divorce the flail mower, turn the rest of it sideways , put a hopper over the auger and be done. You're left with a heavy duty right angle gearbox and most of a fail mower that could pretty easilly be put together to make a dedicated 3pt flail mower.
  5. #25
    Join Date
    Apr 2006
    Posts
    2,177
    western NC
    Ventrac, Steiner
    Just get yourself a straw blower with frail beater chains. then you can direct the discharge shute any direction you want. Might have to feed with shovel, or you can get fancy and build a hopper box with a conveyor to feed the manure into the blower. Naw, probably cost more than just buying a spreader.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
