Results 1 to 10 of 10
  1. #1
    Silver Member SuperDuty335's Avatar
    Join Date
    Jan 2009
    Posts
    133
    Lincoln County, NC
    Default Skid steer auger build
    I didn't build the actual auger, but I did gather/build/install the rest of the assembly for a skid steer mounted auger. The auger itself is a 9" diam. with replaceable knives and spiral tip. The gearbox is a 58 horsepower, 3.14 ratio Omni brand with a Chief Hyd. motor with max. torque of 3026 in/lbs and up to 20gpm with a max. 2400psi. The final rpms at max. pressure/flow will be around 117 which, in retrospect may be too much; or maybe it will bore really fast! I sold my skid steer before I finished it so it has yet to be tested. Anyone want to try it out?
    Attached Thumbnails Attached Thumbnails Skid steer auger build-007-jpg   Skid steer auger build-008-jpg   Skid steer auger build-009-jpg   Skid steer auger build-011-jpg
  2. #2
    Join Date
    Aug 2009
    Posts
    96
    Default Re: Skid steer auger build
    Where did you get the hyd motor and auger drive?
  3. #3
    Join Date
    Apr 2008
    Posts
    136
    Hunterdon Cnty, NJ
    Kubota B7800
    Where are you located? I would love to help out if you are in the Tri-State.
  4. #4
    Join Date
    Jan 2009
    Posts
    133
    Lincoln County, NC
    Bare-Co and Surplus Center have gearboxes. Bailey and Surplus Center have hyd. motors. After I tallied all the expenses (especially the Omni gearbox) I could have bought an auger for a little more money; It was fun though! I'm in NC.
  5. #5
    Member
    Join Date
    May 2009
    Posts
    29
    Quote Originally Posted by SuperDuty335 View Post
    It looks great! I got a auger, gear box from a 3pt and it had a hyd motor already mounted on it, from a DOT sale. I quick mounted it to used but it's just rig up. Your on the other hand look a lot better then mine. I have a light duty skid steer I would like to make a lighter gear box's and more compact later.
    I made my auger bigger. I needed a 20" auger for telephone poles and I had three 10" augers one look like it was cut down smaller to a 10" so I use it to make it bigger. I add 1/8" plate steel and a plasma cut. I made a jig out of wood and cut two 1" hole in the wood for the tip of the plasma cut can sit in. I drill a hole for the pivot in the center of the the steel and the wood jig. I made two 20" circles and a cut a 10" out the inside. Then I started to weld it starting at the bottom and pulling the steel up with a ratchet strips and welding it as I bent it up. Then I added a cutting edge out of 1/2" X 1 1/2" steel bar. It works great with only a few spirals on the auger.
  6. #6
    Join Date
    Jan 2009
    Posts
    133
    Lincoln County, NC
    Cool! That's one way to do it.
  7. #7
    Veteran Member GuglioLS's Avatar
    Join Date
    Feb 2005
    Posts
    1,119
    Edgewood, NM USA
    Jinma 354, 1953 Ford NAA Golden Jubilee, Komatsu Bulldozer
    ........SNIP......SNIP.......! I sold my skid steer before I finished it so it has yet to be tested. Anyone want to try it out?
    Nice build! the RPM'S might be a little fast (OK really fast )
    You sold your skid steer what where you thinking
    I'd love to try it out! Is it for sale? how much? When are you coming to New Mexico on vacation to deliver it for me? I live close to I 40 so it would be a straight shot for you
    Larry
    My Fortune cookies:
    If you have to ask if you can do something, you probably can't.
    Life is short, especially if you forget to wake up the next day.
    He who hurries wastes time.
    If you must select between two evils, choose the one you haven't tried before.
    Tractor hydraulics is not rocket science.
  8. #8
    Join Date
    Jan 2009
    Posts
    133
    Lincoln County, NC
    New Mexico. Hmmm... if I leave now it will take 12.3 days in my old truck. I'm anxious to try it out to see just how fast it is; I would prefer ~70rpms. I goofed on my calculations when I ordered the motor. Simple division is so hard sometimes.
  9. #9
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Tell you what I will meet you at Tucumcari, NM You can be on your way back home before Larry knows what happened.
    steve
  10. #10
    Join Date
    Jan 2009
    Posts
    133
    Lincoln County, NC
    Hire one of those top secret spaceships from Dulce to fly out here and pick it up. I hear they scoot along at 7000mph.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
