Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Veteran Member kebo's Avatar
    Join Date
    May 2006
    Posts
    2,063
    Lexington, SC
    2001 John Deere 790 4x4, bar tires
    Default Here's my 3pt Reese hitch adapter (Handy Hitch)
    Finally got my handy hitch welded together, painted up, and ready to hook up to the tractor! The first picture is my parts list. I basically started with a medium duty 1" reese towhitch for a small pick that I got off of craigslist cheap. It was an adjustable width design which is what the three holes on either side were for. I got a 2" receiver at TSC and welded it on top of the plate that the safety chains hook to. The upright member is 2" square tubing, the braces on either side of it are made from 1 1/2" angle stock. The two end plates for the draft link pins are made from 1 1/2" thick bar stock, while the two pieces at the top for the top link pin are made from 3/8 thick bar stock. I ordered some 3/8 weld on grab hooks from AgriSupply. The little triangle brace is also 3/8" stock.
    The next picture is after all the welding was done. I confess this is not my welding, but I wish it were. I was fortunate to find a retired welder (also through craigslist) who works pretty cheap, he only charged me $25 for about 1 hr and 45min of welding. He does good work, and he works fast too so I will probably use him again.
    This is a closeup of the reese hitch. I included this so you can see the offset I had to put in it because of the 1/4" thick plate made for the tow chains. I could have cut off some of the reese hitch to slide it back further, or maybe filled in the gap with some more material but I decided to leave it as is. The reason this 2" receiver is on top is because if you look at the first pic real close, you will notice there is 1" receiver hiding underneath the plate for the tow hooks.
    Here's the finished product, I think it looks great!! You may notice I left the top open, that's for future expansion? I don't have a GN trailer so I didn't need another ball on top. I may try and add a receiver on top made from either standard 2" sq tube or maybe some round tubing so I can add a short (prolly about 4ft long) light duty boom pole.. Looking back, I now wish I had made the vertical member about 4" taller though, that would give me more area to weld (and brace) a receiver on top of it for the boom. I can make it work as it is, but will probably have to add some more tubing on top of it. I may weld a large D-ring midways of the vertical member later on too. Now, to come up with some attachments to use with it. I have an idea for a "pan" of sorts to use to skid logs with. I also want to make an adapter that will let me pop in a subsoiler, or change it out to a middlebuster for a one row plow. I have some other ideas for improvements/changes I want to do/make for my tractor and/or the attachments I use with it. I'm already working on a bracket to carry my chainsaw and a fire extinguisher next. I think you will like it once you see it. I'm gonna copy the way Foggy did his tool box for his 790 (hope you don't mind Foggy!). Also, I have plans to fabricate a light bar to go on top of the ROPS too. Just have to find time to do all this neat stuff, but it's deer season from now until Jan 1st and I need to fill my freezer!
    Nothing could be finer than riding my JD790 in South Carolina!!
    2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, Leinbach PHD with 9" & 12" augers, King Kutter II 60" Rototiller, Leinbach middlebuster, Leinbach #11 Field Cultivator, boom pole, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
    Nothing runs like a Deere, or smells like a John....
  2. #2
    Join Date
    Jul 2007
    Posts
    857
    Hagerstown, MD
    '05 Kubota BX1830
    Default Re: Here's my 3pt Reese hitch adapter (Handy Hitch)
    Nice. I use mine quite a bit. During the mowing season, I leave it on to move my trailers, mow under/around them, then move them back. It is one of my most used attachments.
    '05 Kubota 1830
    HST, FEL, 54" MMM, Canopy,
    Scraper blade, Box blade, Pallet Forks for 3pt,
    Boom, 7' front mount snow blade,
    14" Bottom plow, Rototiller
  3. #3
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,446
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Nice build. Just wondering why you did not just buy the hitch tube and use a piece of 2"x2" stock for the horizontal part instead of starting with a hitch that was the wrong size? Probably would have been cheaper. Also wondering why you put the lower hitch pins in that way, pointing in?
    Chris
  4. #4
    Join Date
    May 2006
    Posts
    2,063
    Lexington, SC
    Chris, I bought the reese hitch thinking it would fit on my Saturn Vue, which is my daily driver. I wanted a hitch so I could add a hitch haul to carry a cooler etc on the hitch hauler. When I realized it would not fit, I had to come up with another use for it! Looks like I will have to go to uhaul and have one installed that's made just for the Vue. The 1" receiver actually strengthens the plate as it goes from the plate to the frontside of the 2" sq tube and is welded directly to it.
    The hitch pins are reversible, they are only finger tight at the moment. I have the easy change so it should work/fit with the pins set either way.
  5. #5
    Join Date
    Sep 2009
    Posts
    82
    Green bay, Wi
    09 farmall 45w/ 350 loader 08 cat 420e w/cab john deere 110 Inter dump truck w/plows 06 Arctic cat Prowler
    This weekend I built a 3pt hitch and log hauler. I put a cutting edge on the bottom to push up logs with out using the FEL. I haven't tried it yet hope it works good.
    Attached Thumbnails Attached Thumbnails Here's my 3pt Reese hitch adapter (Handy Hitch)-pa200276.jpg   Here's my 3pt Reese hitch adapter (Handy Hitch)-pa200278_01.jpg   Here's my 3pt Reese hitch adapter (Handy Hitch)-pa200280.jpg   Here's my 3pt Reese hitch adapter (Handy Hitch)-pa200277_01.jpg
  6. #6
    Veteran Member MJPetersen's Avatar
    Join Date
    Feb 2007
    Posts
    1,249
    Warsaw, Poland
    YM 1510-D
    Kebo, good job in putting something to use that would have just collected dust in some corner. I would have 2 suggestions: 1) round off the corners of the 3 pt attach points. (An angle grinder with a cutoff disk and a flap disk will do wonders. Shirt sleeves, elbows and shin bones will thank you.) 2) with the top open the bottom needs to be also. (Water and moist debris will collect.)
    Mike
    "In all your ways acknowledge Him and He will direct your paths." Solomon
    YM1510D, YM 1202 tiller, The following home made tools: Quick Hitch, KK copy dirt scoop, imitation Gannon rollover box blade, Forks on 3pt, a Rear Blade with gauge wheels and a 1.5 yd dump trailer.
  7. #7
    Join Date
    Feb 2007
    Posts
    1,249
    Warsaw, Poland
    YM 1510-D
    Quote Originally Posted by sparker133 View Post
    What is the tray that is between the grab hooks? Is that for a winch?
    Mike
  8. #8
    Join Date
    May 2006
    Posts
    2,063
    Lexington, SC
    Quote Originally Posted by MJPetersen View Post
    Mike
    Mike, I did file all the sharp corners so they are rounded off somewhat, so they're not like little daggers waiting to jab someone (me).
    Also, the welder made one goof in his welding sequence.... He welded the hitch on first, then he added the upright vertical member. Once he did that, he couldn't get to the inside weld on that vertical piece so it has a narrow 2 inch gap at the bottom of it to let water drain out. Looks at the third picture closely and you can see what I mean. I won't be storing this one outside anyway. Thanks though!
  9. #9
    Join Date
    May 2006
    Posts
    2,063
    Lexington, SC
    Mike
    I wondered that too, I bet it's for loose chains to lay in.
  10. #10
    Elite Member
    Join Date
    Apr 2009
    Posts
    3,202
    adirondacks
    Built one just about like that this past summer. Comes in real handy and sure makes hooking and unhooking easier. I painted mine bright yellow, for some reason these things seem to be shin busters
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
