VERY NICE, okay next question which way does it rotate, if you were standing on the right side....Tractor would be facing towards your left shoulder????
Next question how did it do on leveling?
Rotation - if you are standing as you mentioned...it would rotate Clockwise.
Because I'm not done, it didnt level too good...well, It worked great, but I know it can be better & easier once I get the gauge wheels.
leveller said:
how big in diameter is your drum? How wide is the drum? How far apart are your teeth and how long are they? How many teeth in total?
Drum Dia: I used 6" pipe so the OD is something like 6.625"
Width: my drum is 75" wide
Tooth Spacing: Very tough to answer that one because its tricky...long story short is they are 5" apart from each other, but the spacing from row to row is funky. I duplicated the Harley tooth setup exactly. Easiest thing I can tell you would be to find a harley somewhere and take pics/measurements yourself so you can see it.
Total Teeth: I cant remember exactly, something like 118 or so...I CAN tell you it took me 9.5 SOLID hours (No breaks except to drink a pepsi and return said pepsi to the earth
Raw Dodge said:
I love what you did with the rake! You did one heck of a nice job,but I think you really need to add 2 adjustable guage wheels to the back of the unit.
Thanks! As for the gauge wheels in my first/original post I mentioned I WILL be making some, I got most of the parts (Wheels, tires, hubs, etc) in the basement, but I was devoting my time to getting the actual rake itself done first. I've got the gauge wheels, End Plates & Rubber Deflector to build...Safe to say the "tough part" is done though...
