HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-01-2009, 01:37 AM   #1 (permalink)
Member
Default Home made trailer dolly?
I have a lot of things on trailers and vehicles that don't run that need to be moved around in a tight space. Some of them I can push, but some weigh 8,000#+, and I'd rather not.
I could buy something like this:
Power Caster,electric trailer mover dolly, boat dolly, toy hauler
But I don't like the electric idea, or the price tag. I was thinking it wouldn't be too difficult to hook up a 5hp small engine (already have an old briggs that runs good laying around) to a truck tire, geared for a top speed of 2-3mph, and end up with something similar. Am I wrong? Anybody ever make anything like that before? Basically a self propelled lawnmower, with some serious grunt.
I was thinking if I use a truck tire I could also use a disc/drum brake for safety. Another idea would be to add a concrete block down low for extra weight and traction. I figure if that electric thing is only 1/4HP I should have a ton to spare with a 5hp engine.
zmoz is offline   Reply With Quote
Old 11-01-2009, 01:04 PM   #2 (permalink)
glh
New Member
Default Re: Home made trailer dolly?
first off i have not made one but i had put some thought into it once
and i dont think you will want to use a truck tire as the trailers tongue needs to be able to go over it for sharp turns and the weight will need to be centered or just behind center, between two smaller tires.
they use electric coz its easy to make it go both ways (forward and back)
you will need a gearbox or something to be able to do that.
i was thinking of using one out of a old very small riding mower (i picked that coz i already had a good one with 3 speeds forward and R that was chain drive
you will still need to gear it down to walking speeds
and adding a concrete block ??
why? the trailer should be more than enough
anyways look here Trailer Tug Pro: The Gas Powered Trailer Mover – Photos & Videos Gallery and you might be able to get ideas for yours
take lots of pic's and post um as you go
hope this helps
gary...
glh is offline   Reply With Quote
Old 11-01-2009, 10:44 PM   #3 (permalink)
Member
A lot of good ideas there, I haven't seen a commercial gas one before, I'm sure I can steal a lot of their ideas too. Vertical engine and lawnmower transaxle seems like an interesting idea. I have an old manual trans out of a truck with a granny gear, I wonder if I could even spin that with a 5hp engine? Then I could have 6:1 ish output from the engine forward/reverse/neutral.
The reason for the concrete block is because I want to be able to pull a dead pickup truck that weighs 6,000+ lbs with no tongue weight (tow strap) up a *slight* incline. I realized the need for this when my TOW TRUCK broke down and I had to call another one. *sigh* That way I could get better traction and have better braking ability. (although someone would be in the truck to operate the brakes)
I might also incorporate a winch into this thing, with it chained down or something.
Old 11-02-2009, 12:38 AM   #4 (permalink)
glh
New Member
hmmm sounds to me like you need a riding mower with a hitch on the back
about 3 weeks ago i made one that would bolt to the back of my friends J.D. and it will pull a trailer like it was nothing. we had to let some air out of the tires to pull his 89 1ton ford up the driveway
anyways.... make sure you make the part that comes back toward you for the handles, pretty long. for leverage so your not trying to fight it
another idea i was looking into was using a Rototiller
taking the tiller off moving the motor back and installing the ball mount over the tires.
and i'm still thinking of that one.
or at least use the gear box and clutch setup
5hp or even alot bigger would be just fine and that kind of gearing is about what (IMO) you would be looking for
Old 11-02-2009, 02:37 AM   #5 (permalink)
Member
Quote:
Yeah, though I'm trying to take up less space. We'll see what's on craigslist though.
I might buy one of those ~13hp Honda clones for cheap with electric start, I'm liking the idea of the truck trans because it has two PTO connections - one would work for a winch, the other for hydraulics, which I could use as a powerpack for the logsplitter I need to build...
Old 11-03-2009, 04:04 PM   #6 (permalink)
Iplayfarmer's Avatar
It sounds like you're going to end up with a fully functional tractor by the time you get done... PTO, Hydraulics, Weight box (concrete block). There has to be a way to add a FEL .
I think it could be useful. Like you said, 5 hp is more than enough power. If you do it right, you'll have a tool that is great for multiple uses, but doesn't take up much space.
__________________
If necessity is the mother of invention, laziness is the father.
Iplayfarmer is offline   Reply With Quote
Old 11-03-2009, 09:35 PM   #7 (permalink)
Member
Quote:
Yeah, at first I was thinking "small, simple, cheap", now I'm gonna end up with another $2,000 project that takes 5 years and all my space. LOL
Maybe I should just buy a $500 pickup and cut the whole body off?
Old 11-03-2009, 09:45 PM   #8 (permalink)
Elite Member
Diamondpilot's Avatar
Find a old Roto Tiller for cheap. I got one for $50. Its a Craftsman that I could take the tines off of and put a heavy caster wheel on the front of like off a bush hog and there you go.
Chris
Diamondpilot is offline   Reply With Quote
Old 11-13-2009, 01:57 AM   #9 (permalink)
New Member
bladerunner3's Avatar
Here's an idea... Use a cordless drill for the power source. Lots of torque there. When you're done, unchuck the drill and use it for something else.
bladerunner3 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.23844 seconds with 9 queries
