Oasis
Member
Thanks again to all of the folks here. I've joined the numbers with my version of a 3PH splitter.
Why/How did I decide on DIY?
First, I enjoy these projects and I had some post surgery down-time (no heavy lifting for a few weeks).
And:
I wanted a 3PH type because it's compact for easy storage (about 11 months of the year here), for off-road driving through my woods, and for low maintenance (no motor, tires...). I could find plenty of gas powered tow behind units locally but not 3PH types.
I cut 14" wood for our stove (16" is the standard in this area). I certainly didn't need the 24" capacity found on the retail units I looked at.
I considered ordering NorthernTools: Powerhorse Horizontal Log Splitter 3 Pt. with 3in. x 18in. Cylinder $599 (+ $175 shipping). But I hate not seeing something like this before I buy _and was not thrilled about spending 22% of the cost on shipping.
99% of my wood is straight grain Douglas Fir that is pretty easy to split. I could select the hydraulic cylinder specifications (force and speed) based on my tractor's flow and pressure.
So, here's my DIY version
Materials:
Some of the steel was on hand, the rest I bought for $0.35 Lb. The H beam is 6x6 @ 20# pf, other is 3/8" to 1" plate, some: angle, sq tube and hitch pins. $35
Parts:
Cylinder 3.5" x 1.5" by 16". For my tractor it specs @ 24000/19500 Lbs (push/pull) @ 2.2/2.7 inches per sec (push/pull). $99
Valve splitter w/ auto detent. $59
Hose and fittings about $100 (I could have spent less here but wanted to use elbows and hose sheath)
Total cost about $300 (less gas, rod, paint..)
I also put together a quick connect hydraulic pressure gauge for about $20.
Splitter Specs:
Length 64"
Weight 200 Lbs (guesstimation)
Maximum wood capacity 17"
Complete push/pull cycle time 13 seconds (maximum)
Splitting cycle time 8 seconds (typical)
See photos-
more coming- The splitter is currently apart for painting.
And:
Materials:
Parts:
Splitter Specs:
Length 64"
See photos-
