Results 1 to 8 of 8
  1. #1
    New Member bladerunner3's Avatar
    Join Date
    Nov 2009
    Posts
    8
    Default Hay Elevator
    Here's another project in the making, one section of a 16' hay elevator. This was welded up out of 1" square tubing, 1/16" wall. I used a couple magnetic welding squares for all the 90 degree angles. Made the fabrication go a LOT faster. Cold-rolled rod was welded into the two section that will be in the middle of the elevator for added strength. The sections will be compatible and will bolt up to Snowco sections. I have included a photo of the project, and another of a used Snowco elevator. This one sold for $795 used!
    Used Equipment for Sale Pg. 1 With all parts and material, and a used 1/2 or 3/4 HP motor, one should be able to build one for only a couple hundred $$.
    Attached Thumbnails Attached Thumbnails Hay Elevator-snowco16ftelevator-1-jpg   Hay Elevator-7146d25lbsmagnetic-jpg
    Attached Images Attached Images
    Last edited by bladerunner3; 11-12-2009 at 09:42 PM. Reason: Added another 2 images and supporing text.
  2. #2
    Join Date
    Dec 2008
    Posts
    898
    Buffalo, New York
    318 John Deere, 4200 John Deere, 1947 John Deere "M"
    Default Re: Hay Elevator
    Guess I don't quite understand your project question! If your trying to duplicate the yellow one, you sure look on your way with the fabrication in the other picture. The cost of, Rail chain, Motor, drive chain, pillow blocks, shafts, bearings, sprockets, etc, tend to add up!!! ~Scotty
  3. #3
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Quote Originally Posted by Scotty370 View Post
    I don't see a question ?
    ::Sent from a standard desktop keyboard::
    My Photobucket
  4. #4
    Join Date
    Dec 2008
    Posts
    898
    Buffalo, New York
    Quote Originally Posted by Willl View Post
    Oops! My 'Bad' Willl ! I inferred the question myself, that a guy could put one together "for a couple hundred bucks!" Just sayin', the cost of, Rail chain, Motor, drive chain, pillow blocks, shafts, bearings, sprockets, etc. I think, woud put a guy well over that. It also appears that BR3 is also using new steel. Don't get me wrong, it's a nice looking build!!! ~Scotty
  5. #5
    Join Date
    Nov 2008
    Posts
    550
    Central Illinois
    Many JD
    I made my own a few years back. I made a jig to hold the rails and spacers in place while welding, Used a tubing bender to make loops on the ends. I had a fab shop bend the upper guide for the chain, I bought the return guides and sprockets from Snowco. For the drive I used a 15 to 1 ratio right angle drive with a 2/3 C-face motor drive. Chain came from Sloan Express. I won't be home for a few days but can get pictures of the drive and tail end if you like.
    Dan
  6. #6
    Join Date
    Feb 2007
    Posts
    1,627
    easten Colorado
    JD 4020
    I would like to build some thing similar for carrying up shingle bundles, to a roof guessing one would want a little longer length 20 to 24 foot,, but one could run it steeper for shingles and if you only had two points or even one catch for the shingle bundle would be enough, make a tray to put the shingle on and let the chain come around and catch it. I have just about given up on roofs except for my self. Something about my knees,
  7. #7
    Join Date
    Nov 2009
    Posts
    8
    Dan,
    What kind of tubing bender did you use for the ends?? Did you bend round tubing or square? Would like to see some pix of your finished product. Thanks!
    Paul
  8. #8
    Join Date
    Nov 2008
    Posts
    550
    Central Illinois
    Many JD
    Here are a few pictures I took tonight. The bender was one of those you bolt to the floor and has the big arm you pull the tubing around a die. I could not make the end loops in one bend. I made 8 loops, cut them as needed and welded them back together. All 1" tubing.
    If I were to build another I would use lighter gauge steel and fewer cross braces. The thing weighs quite a bit. The chain return guides and sprockets came from Snowco. The chain track was bent at a local metal shop. I made a wood jig to hold all the ladder parts square while tack welding. I used the deck on my goose neck trailer for a work table. I think it is 18' long but I can't remember.
    The bad thing is there is no belt to slip in case someone gets tangled in the chain.
    Dan
    Attached Thumbnails Attached Thumbnails Hay Elevator-img_0524-jpg   Hay Elevator-img_0525-jpg   Hay Elevator-img_0526-jpg   Hay Elevator-img_0527-jpg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
