Page 2 of 15 FirstFirst 1234512 ... LastLast
Results 11 to 20 of 148
  1. #11
    Member Oasis's Avatar
    Join Date
    Oct 2009
    Posts
    41
    Oregon Coast
    JD 790
    Default Re: show your homemade splitter pics here
    My DIY 3PH splitter. It's working just fine. Pretty fast and compact too.
    Link to post: http://www.tractorbynet.com/forums/b...-splitter.html
    Attached Thumbnails Attached Thumbnails show your homemade splitter pics here-splitter1-lo-res.jpg   show your homemade splitter pics here-splitter2-lo-res.jpg   show your homemade splitter pics here-splitter3-lo-res.jpg   show your homemade splitter pics here-splitter4-lo-res.jpg   show your homemade splitter pics here-splitter5-lo-res.jpg
    show your homemade splitter pics here-splitter6-lo-res.jpg   show your homemade splitter pics here-dsc01107_low_res.jpg   show your homemade splitter pics here-dsc01345_low_res.jpg   show your homemade splitter pics here-dsc01347_low_res.jpg   show your homemade splitter pics here-dsc01104_low_res.jpg
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #12
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,531
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Nice job. Just 1 question, is the push arm removable? Just wondering about maintenance.
    Chris
  4. #13
    Veteran Member smfcpacfp's Avatar
    Join Date
    Nov 2007
    Posts
    1,253
    Sands Township, Marquette Co, Michigan
    Kubota B3030HSDC
    Built this 30 years ago:
  5. #14
    Veteran Member GuglioLS's Avatar
    Join Date
    Feb 2005
    Posts
    1,111
    Edgewood, NM USA
    Jinma 354, Ford 1953 NAA Golden Jubilee, Komatsu Bulldozer
    Here's one I put together with scrap metal.
    Two mobile home tongue I beams 3" wide x 12" tall x 3/16" thick welded together side by side to make a 6" x 12" "super" I beam.
    4-1/2" x 30" stroke hydraulic cylinder from e-bay. It has a 1-1/2" push rod and ~ 25 tons of force. Prince auto return detent valve from Northern Tool along with all the hoses and fittings.
    Here is the result:
    Put the whole thing on wheels to tow it around. I use the tractor hydraulics to power it from either my Jinma tractor, 1953 Ford TLB, or Komatsu Bull Dozer depending on which needs the workout.
    All the push ram parts are 1" thick x 6" wide The valve is mounted to the cylinder with a piece of angle iron this located the valve in a very handy spot.
    Close up of push ram construction:
    Wedge cut out of 1"x6" cold rolled.
    The two 45* wedge angels cut on bandsaw:
    Action Video:
    Here is a REAL good example of how not to split a log (one for the safety police)
    And of course running it off the dozer hydraulics at idle:
    Larry
    My Fortune cookies:
    If you have to ask if you can do something, you probably can't.
    Life is short, especially if you forget to wake up the next day.
    He who hurries wastes time.
    If you must select between two evils, choose the one you haven't tried before.
    Tractor hydraulics is not rocket science.
  6. #15
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,107
    Ontario, NY
    Kubota BX24
    GuglioLS you need to run a half moon or almost full circle bead of weld on the pushing block face. This will help to prevent slipping of logs when splitting. It shouldnt be a very pretty weld- a rough weld is best due to the unevenness of the beads acting like teeth to hold the wood in place.
  7. #16
    Veteran Member Gizmo2's Avatar
    Join Date
    Jul 2006
    Posts
    1,917
    New York
    JD 2320
    Quote Originally Posted by radioman View Post
    I would add, A higher cutting wedge also prevents most of this.
    JD 2320, 200CX FEL/61" bucket , 46 BH/16" bucket, FEL Forks, 72" Snow Blade, Landscape Rake, Ballast Box, PHD, The Wife
  8. #17
    Join Date
    Feb 2005
    Posts
    1,111
    Edgewood, NM USA
    So I take it you liked the flying log vid?
    "It shouldnt be a very pretty weld" - Well that should be easy LOL
    Great advise, instead of a crappy weld how about a 6"X6" square chunk of expanded metal welded to the pusher face ?
    Larry
    Attached Thumbnails Attached Thumbnails show your homemade splitter pics here-dsc02798.jpg
    My Fortune cookies:
  9. #18
    Join Date
    Feb 2005
    Posts
    1,111
    Edgewood, NM USA
    Quote Originally Posted by Gizmo2 View Post
    Since taking those videos several years ago, I've done exactly that. Attached is a pic of the second story cutting wedge I added. Total height is now 12". Oh and I added some "wings" to catch the logs so they don't fall off. It still needs a few improvements here and there but I'm getting close to a "safer" more efficient log splitter.
    Larry
    Attached Thumbnails Attached Thumbnails show your homemade splitter pics here-dsc02799.jpg
    My Fortune cookies:
  10. #19
    Platinum Member Zork's Avatar
    Join Date
    Dec 2003
    Posts
    704
    Virginia
    '04 Branson 3520, '51 Fergy, '96 MTD 18/46, '02 Craftsman GT5000/48
    This is an early circa 80's model made from the old Northern Hydraulics catalog....what a beast!
    Attached Thumbnails Attached Thumbnails show your homemade splitter pics here-cl4092crop2.jpg   show your homemade splitter pics here-img_4089crop.jpg   show your homemade splitter pics here-img_4091crop.jpg   show your homemade splitter pics here-img_4090.jpg
    He who is full loathes honey, but to the hungry even what is bitter tastes sweet.
  11. #20
    Join Date
    Jul 2006
    Posts
    1,917
    New York
    JD 2320
    Quote Originally Posted by GuglioLS View Post
    Larry
    I like it, nice addition. I started out with a 12" wedge then added two pieces of heavy angle iron. I always wanted to add wings to the one I built but never got around to it, it's a good idea.
    Notice the axe mark on the wedge? This happened just before I added the angle iron to the wedge. I had a block of wood stuck on the wedge and tried to remove it with my axe, live and learn.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
