Page 3 of 15 FirstFirst 12345613 ... LastLast
Results 21 to 30 of 148
  1. #21
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,531
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default Re: show your homemade splitter pics here
    Quote Originally Posted by GuglioLS View Post
    So I take it you liked the flying log vid?
    "It shouldnt be a very pretty weld" - Well that should be easy LOL
    Great advise, instead of a crappy weld how about a 6"X6" square chunk of expanded metal welded to the pusher face ?
    Larry
    Great idea Larry. .
    If you look at my splitter I added 2 pieces of 5/16" key stock to the foot to keep the logs from flying.
    Also curious if you did the welding with your wire welder? I tacked everything on mine and did all the finish welding on non crucial parts with my Hobart 187 but had the crucial stuff done by a welding shop. I was surprised to see him use a stick welder on this.
    Chris
    Attached Thumbnails Attached Thumbnails show your homemade splitter pics here-log-splitter-004.jpg
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    Join Date
    Jan 2007
    Posts
    12,531
    Daleville, IN
    Quote Originally Posted by smfcpacfp View Post
    Built this 30 years ago:
    That thing is a beast!
    Chris
  4. #23
    Veteran Member GuglioLS's Avatar
    Join Date
    Feb 2005
    Posts
    1,111
    Edgewood, NM USA
    Jinma 354, Ford 1953 NAA Golden Jubilee, Komatsu Bulldozer
    Quote Originally Posted by Gizmo2 View Post
    I like it, nice addition. I started out with a 12" wedge then added two pieces of heavy angle iron. I always wanted to add wings to the one I built but never got around to it, it's a good idea.
    Notice the ax mark on the wedge? This happened just before I added the angle iron to the wedge. I had a block of wood stuck on the wedge and tried to remove it with my ax, live and learn.
    Attachment 146273
    I often wondered what the effects would be on splitting adding those angle iron pieces to the wedge like yours? You may have noticed the type of wood I have has a tendency to fly apart with just the 1" thick wedge I have now, so you might understand me not doing that just yet. Your splitter and wedge look heavy duty, nice work on that.
    "Notice the ax mark on the wedge?"
    I saw that and wondered if you add a tick mark for every severed appendages so I figured I better not ask I've had a few logs "stick" but never thought of taking an Axe to my splitter. That was quick thinking on your part
    "but never got around to it"
    OK here ya go......
    Attached Thumbnails Attached Thumbnails show your homemade splitter pics here-aroundtuit.jpg
    My Fortune cookies:
    If you have to ask if you can do something, you probably can't.
    Life is short, especially if you forget to wake up the next day.
    He who hurries wastes time.
    If you must select between two evils, choose the one you haven't tried before.
    Tractor hydraulics is not rocket science.
  5. #24
    Platinum Member Dead Horse's Avatar
    Join Date
    Feb 2009
    Posts
    575
    New Hampshire
    I got lucky and found a used American TMH 30 for a very good price. Good thing, two because I have split over 35 cord in the last 14 months, 24 in the last 6 alone. Thank gawd for a four way wedge!
  6. #25
    Join Date
    Feb 2005
    Posts
    1,111
    Edgewood, NM USA
    Quote Originally Posted by Diamondpilot View Post
    Great idea Larry. .
    Chris
    Thanks Chris,
    I like the anti slip key stock add on, that came out clean. Looks like your in the process of adding a ramp of some sorts? What's it's purpose? Almost looks like a conveyor could be added in that area to become a full fledged wood processor.
    "Also curious if you did the welding with your wire welder? " - I stick welded everything simply because it was built before owing my "glue gun". Not to start a Stick vs MIG war, I've done plenty of both. IMHO stick (depending on rod, amps, technique, ground placement) can penetrate deeper. But that's really not the point. MIG could have easily been used with no compromise in strength. Had I owned the MIG at the time that's what I would have used simply because (for me) it's allot easier with no slag to chip off.
    Larry
    My Fortune cookies:
  7. #26
    Join Date
    Jan 2007
    Posts
    12,531
    Daleville, IN
    Thanks Chris,
    Larry
    Larry if you are talking about the piece of plywood, its simply a table to catch the wood. I stand on the opposite side and run the valve with my left hand and catch half the log with my right. The table catches the left side piece.
    As for the angle iron flares, mine work great to open up the wood. My wood never pops. I do sharpen my wedge with a file so its razor sharp. This really helped with the popping.
    Chris
  8. #27
    Member Oasis's Avatar
    Join Date
    Oct 2009
    Posts
    41
    Oregon Coast
    JD 790
    Chris, My push plate assembly is welded. Shouldn't need to remove it but could torch it off in a couple of minutes if I had to.
    Wedge flare:
    It appears to me that the narrow wedge section works well to initiate the split; then the wide section (welded angle) does a good job of pushing the already split wood fully apart. I think some pieces would need more push distance (time) to fully come apart without the wide wedge section.
    Plate friction:
    I did something similar to the welded dogs... by welding a bead along the top of the push plate surface. I think it helps keep the wood from sliding but probably not as much as squarely cut wood.
    Cylinder length:
    I'm glad that I matched the cylinder length to the length of wood that I cut. There's very little wasted lag time.
    Nice splitters! I did a lot of thred searching during my build. Thanks all
  9. #28
    Member andymil's Avatar
    Join Date
    Jan 2008
    Posts
    29
    20 mi east of Pittsburgh, PA
    Case 8116 Skidsteer
    More pictures for those of you who can't get enough. It only took me about 15 years to finish it. We move twice before it was done. It's been working well for about 8 or 10 years now.
    Attached Thumbnails Attached Thumbnails show your homemade splitter pics here-100_1517_-1024_x_768-.jpg   show your homemade splitter pics here-100_1518_-1024_x_768-.jpg   show your homemade splitter pics here-100_1519_-1024_x_768-.jpg   show your homemade splitter pics here-100_1520_-1024_x_768-.jpg   show your homemade splitter pics here-100_1521_-1024_x_768-.jpg
    show your homemade splitter pics here-100_1522_-1024_x_768-.jpg   show your homemade splitter pics here-100_1523_-1024_x_768-.jpg   show your homemade splitter pics here-100_1524_-1024_x_768-.jpg   show your homemade splitter pics here-100_1525_-1024_x_768-.jpg   show your homemade splitter pics here-100_1526_-1024_x_768-.jpg
    show your homemade splitter pics here-100_1527_-1024_x_768-.jpg   show your homemade splitter pics here-100_1528_-1024_x_768-.jpg   show your homemade splitter pics here-100_1529_-1024_x_768-.jpg   show your homemade splitter pics here-100_1530_-1024_x_768-.jpg
    Daaaad, can you fix this?
  10. #29
    Silver Member Raw Dodge's Avatar
    Join Date
    Apr 2009
    Posts
    229
    Nice splitters guys!
    Cat 246 SS,Homemade 35T log splitter,
  11. #30
    Bronze Member dngspot's Avatar
    Join Date
    Jan 2009
    Posts
    73
    andymil
    What type and gpm pump are you using? You splitter looks great.
    A real man builds it... Then his wife shows him what he did wrong.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
