Garden Tractor Dump Body
   / Garden Tractor Dump Body #1
oneparsec
Has anyone converted and and added a dump body to a garden tractor? I've got an old Roper tractor thats been sitting in the back woods for a few years, (needs to be repowered). My wife has a hard time pushing the wheel barrow after cleaning out the stalls in our barn, and I thought if I could add a dump body to the tractor, it would make it much easier for her when I'm not around to help. Any idea's or suggestions? Anyone done this before?
   / Garden Tractor Dump Body #2
Don't laugh.......but I have $23.74 in this (wood and one hydraulic fitting). It'll look better with some paint (gotta get rid of that ugly green and yeller..), and I have since made a battery box and got it wired up.
   / Garden Tractor Dump Body #3
I can't remember where I saw them, maybe on another forum, but a couple of people built some really neat ones:
Thanks for the photos and ideas, give me something to work with
   / Garden Tractor Dump Body #5
How would this work using a lawn mower as the base machine?
What is it that makes a garden tractor preferable?
Clem
   / Garden Tractor Dump Body #6
Bobodu,
Does your masterpiece have an hydraulic dump? Tell us more about it. Any more pictures? My wife needs one of these. :)
Thanks,
Clem
   / Garden Tractor Dump Body #7
That will work. I like the hood design pretty good. I'm building a dump box on a bolens hydro eliminator. I extened it 36'' and the box is 48x48. The tractor had hyd lift for the deck, so it had a valve that I'm using and I just need to add a longer cylinder positioned in the back to lift the box. I'll do my best to get pics on here when I get a camera. I'm alot better with a welder than a computer. I really enjoy the projects u guys have on here. way to go Jack
   / Garden Tractor Dump Body #8
I don't remember where, but one of the sites had a walk behind one made from a snowblower with a wheelbarrow tub mounted up front. I started building one from a rear engine rider, with a wheelbarow tub in front, but traded it for a laptop computer before it was finished.
   / Garden Tractor Dump Body #9
Does that come with pedals?
   / Garden Tractor Dump Body #10
I looked around and I don't seem to have any pictures of the pump before I covered it up with the wood. But the pump is mounted about halfway down the main frame with a belt going up to the engine. Another belt runs from that back to the tranny and this one has a movable idler pulley to engage the gears. I linked the pulley up to it only tightens the belt when the peddle is pushed. Anyone who has real meat eatin' God fearin" gears knows what a pain it is to put the tractor in neutral every time you move to a new pile. The pump is a 1.7 gpm with a built in valve and this powers a single action ram. Still have to get a big spring to pull it back down because I didn't have enough room to mount the hinge far enough back to let gravity do the job and I had this cylinder on the shelf.
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
11' x 19' All Metal Carport (New/Unused) (A59225)
11' x 19' All...
2025 AGT MX-CRT23 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attach... (A59225)
2025 AGT MX-CRT23...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A58018)
2023 PETERBILT 579...
Heavy Duty 10,000lbs Two Post Car Lift (New/Unused) (A59225)
Heavy Duty...
