Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Nov 2008
    Posts
    107
    Southern Maryland
    Default Clearing saw
    Has anyone ever attempted to convert a weed wacker to a clearing saw?
    Or built a homemade clearing saw?
    I just leased a piece of hunting property that was timbered 3 or 4 years ago and is thick with small trees that are 3-4inches in diameter.
    I want to cut a couple of trails into without going thru with a chainsaw
    (to hard on an old man's back)
    I tried running my 4 wheeler thru but they don't break and I end up getting stuck sitting on top of them
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Gold Member nh DRAGON's Avatar
    Join Date
    Jan 2007
    Posts
    337
    Southern New Hampshire
    Kabota BX2350
    Default Re: Clearing saw
    I found a bolt on head that had two chain ends on it. I works alright for stuff up to an inch or so. They do make saw blade that look like skill saw blades for them but you need a bigger trimmer then I have to run them.
  4. #3
    Bronze Member PHIL850's Avatar
    Join Date
    Apr 2006
    Posts
    98
    MASS and Northeast kingdom of VT
    JD 850
    I bought a Beaver blade for my Ryobi Trimmer and used it to cut some small trees.
    the Blade is circular with a Chainsaw cutting edge. I am attempting to bring back a field
    that is full of small trees, to big to brush hog and not worth anything as far as timber or firewood, in other words, around 3" stuff. I have since bought a used DR Trimmer with a 14 inch beaver blade on it, that I am going to use next spring. It's powered by a 6.5 HP Briggs, and you push it around on two weels. hopefully this will be the back saver i have been looking for. Time will tell. Check out their website to get an idea of how there machine works and then look for a used one on Craigs list / Ebay. Good luck!
    Phil C.
  5. #4
    Platinum Member JohninCT's Avatar
    Join Date
    Jul 2001
    Posts
    919
    Central CT
    Struck Magnatrac 6000, Kioti DK40SE
    If trails are what you want, then consider hiring someone with one of these skid steer mulchers. A few hours and you'll have excellent woods trails.
    YouTube - Denis Cimaf Skid Steer Forest Mulcher DAF-180
    There are a number of guys that operate mulching businesses on the "contruction equipment" forum. Maybe one of them is local to you.
    "I don't do landscaping... I do battle with vegetation"
  6. #5
    Gold Member smiley's Avatar
    Join Date
    Dec 2003
    Posts
    415
    Upstate NY
    My Dad had one of these David Bradleys with one of these brush and tree saws, plow, discs, cultivators, front mounted reel lawn mower, front mount sickle bar mower and home made snowplow. We used it for many years with good results. I remember trying the brush saw only once and that it did the job but tried to kick sideways. You obviously had to watch for dirt and stones.
    Here's a link to the site. David Bradley tractors at work
    Smiley
  7. #6
    Join Date
    Jan 2009
    Posts
    1,554
    Rushville, Ohio
    Massey 180 Diesel
    I put a 5" fine tooth circular blade, from one of those 18V saws, on an old Ryobi string trimmer I wore the string head out on. I did have to make a bushing to adapt it to the trimmer shaft. Works great for cutting honey suckle, and water sprouts. Things too big for a string trimmer. I have cut a few 2 to 3 inchers.., but wouldn't want to do acres of them.
    With the momentum of the blade, I only need to run it about half throttle. Works great to trim around the outside of the pasture, trimming the neighbors "stuff", to keep it from climbing up to the electric fence. Would be sweeter to have a 7" blade, but this is all I had around with fine teeth.
    I do need to make a new guard for it, preferrably metal now. I broke the plastic one, when the blade grabbed, and sucked it into one of the small trees I was cutting.
    Again.., I only run it, no more than half throttle, wear heavy work boots, and my Carrharts.. Hopefully if the bolt breaks, the blade will go another direction.
    Don't reckon' it's any worse than the grass blades they make for them.
  8. #7
    Gold Member
    Join Date
    Apr 2008
    Posts
    405
    Western NY
    Kubota 3030 Ford 2120
    If you can find it, Gravely used to have one for their 2 wheel tractors. It used the same gear box as the 30" rotary mower and was 30" blade if I remember correctly. It was an ANIMAL!! You can buy the tractors pretty inexpensively these days. If you're patient, you can do a basal spray on these these trees using Garlon. They die pretty quickly. I do thinning and getting rid of undesireable species up to 6" dia. w/ Garlon. Backpack sprayer and deisel for a carrier.
  9. #8
    Join Date
    Nov 2008
    Posts
    546
    Central Illinois
    Many JD
    If you can find an old Bachtold weed mower they had a 24" saw blade that could be put in in place of the mower blade. They were made in central Illinois and were used to mow fence rows and field edges. These are comon at farm sales in this area. The DR field mower has taken the place of these mowers.
    Dan
  10. #9
    Elite Member
    Join Date
    Jul 2007
    Posts
    3,223
    3-4" inch diameter trees are getting fairly large to cut with a trimmer/brushcutter. I guess it could be done with patience. The problem you may have is binding. I have not used the type of blade with chain saw teeth to say much about it.
    I had a walk behind string trimmer. It wasn't self propelled, and it was tiresome to push and pull back and forth. Would rather use a plain trimmer myself.
    I also have used David Bradleys. Some of them didn't come with reverse gears, and those aren't fun either. Plus I'm not so sure of using a big circular saw blade without any guard.
    Gravelys are like tanks, but I'm not sure where you'd find one with the circular saw attachment, and I don't think they have guards on them, either. The problem with using the 30" bush hog would be getting the cutter up on top of the tree to chop it, and a 3-4 inch tree is getting to be a fairly good size tree to cut.
  11. #10
    Elite Member
    Join Date
    Oct 2003
    Posts
    2,799
    the Steernbos (Holland)
    Zetor 3011, Zetor 5718
    We put a circular saw blade on our weed eater. IT cuts through anything, even trees. But with stuff over 2 inch its just dangerous, for yourself as well as for the wead eater driveshaft. I would just use the chainsaw for 2 to 3 inch stuff.
    Free scrap is a good investment !!!
    “The worst enemy of life, freedom and the common decencies is total anarchy; their second worst enemy is total efficiency” · Aldous Huxley
    __________________
    1967 Zetor 3011, restoration in progress: Technically new, just needs the cosmetics..
    1973 Zetor 5718, home made loader
    1998 Volvo S70 TDI
    2007 Volvo 440 1.9 TD based dirt buggy, needs time !
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
