Hooked_on_HP
I got my iron worker Wed. and got it assembled yesterday. I got to play this afternoon. I am impressed with how easy it does everything. I didn't even hear the pump groan and I was shearing some 1/4" 3x3 angle. I punched a bunch of holes from 1/4-3/4. So much faster and cleaner than drilling and the holes are exact. I bent up some brackets on some thin metal and found when trying to make a short bend I was better off using the V blocks from my Smithy insted of the lower die that came with it(last pic). When making bends where the ends will be over a 1.5" long the die that comes with it works perfect. I bent some 1/2"x1 flat steel without a problem. One thing I didn't realize is when cutting angle iron you loose a 1/2" of material every time you make a cut. Are other ironworkers like this?
