Hooked_on_HP
I am going to build a 5'x8' tandem axle dump trailer. Part of the frame is going to be 3x1.5x3/16 channel. Is channel strength the same whether it is used flat or on edge?
Bill
Bill
Bill
Bill
The reason for the tandem is so I can load the trailer unhooked, back up to it ,raise the TPH which has a ball mounted on it and drive to where I want to dump. Dump the load drive back to the pile ,lower the TPH to unhook and reload and repeat as necessary. Bill
