Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    Platinum Member glc24's Avatar
    Join Date
    Dec 2009
    Posts
    848
    Southwestern, Pa.
    Default BALLAST BOX BUILD
    Here are a few pics of my box before paint. I was planning to paint it the way it is,but a friend and coworker who knows bodywork offered to "mud" the welds and spray it for me. So I went to the JD dealer and bought a quart of paint,thinner and hardener.......70.00...ouch! Paint wasn't bad,the hardener was the most...40.00!! Enough for a gallon though.
    I made the box out of leftover 1/2"x12" cold rolled. The box tubing is 1-1/2 square with 1/4" wall. The pipes are 2" schedule 40. The pieces of angle are 3"x3"x1/2". I cut 1" off so it would be flush with the edge. The box measures 24" wide,18" deep,and 24" high. The box weighs 380lbs......empty!!
    For the side pins, I'm using 1"x5-1/2-8 bolts with a piece of 1" schedule 40 pipe over the bolts for bushings. The OD of the pipe will give me just about 1-1/2". I cut the threads off a bolt and drilled a hole in the end for a 7/16" locking linch pin for the top pin. I also added a piece of 3/4"x3"x4" inside the box to give me 1-1/4" for the threaded side holes.
    Comments good or bad are welcome
    Greg
    Attached Thumbnails Attached Thumbnails BALLAST BOX BUILD-ballast-box-003.jpg   BALLAST BOX BUILD-ballast-box-004.jpg   BALLAST BOX BUILD-ballast-box-009.jpg
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Gold Member
    Join Date
    Dec 2008
    Posts
    252
    Central Vermont
    2008 Kubota BX2660
    Default Re: BALLAST BOX BUILD
    I built something similar. A bit smaller with thinner steel. I drilled two drainage holes in the bottom. I then coated the inside with Herculiner roll-on bed liner and filled the box with sand. I use the sand as ballast for loader work in the summer and also use it to sand the walk and driveway in the winter.
  4. #3
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Looks great, but hope you are picking it up with a quick hitch.
    Are the pipes in the corners to carry four flags?
    Filling it with concrete? or what?
  5. #4
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,125
    Westminster, MD
    John Deere 4110
    Quote Originally Posted by beenthere View Post
    With half inch plate and those pipe he can almost leave it empty!
    Great looking job GLC, and very nice welding also-what are you using?
    John Deere 4110HST
    FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
    John Deere 4x2 Turf Gator
    View some of my projects/adventures in my Picasa Album
    Simple JDParts Tutorial HERE
  6. #5
    Join Date
    Dec 2009
    Posts
    848
    Southwestern, Pa.
    Thanks guys
    I have a 7/8" hole in the bottom for each pipe.
    I saw a few other members,here and on TractorForum who did the pipe thing for
    manual labor,like shovels,rakes,sledges,that sort of thing.
    Right now,I have a few old metric calibration weights that weight 44lbs apiece,
    I'm going to put six in the box for now and see how well 644lbs works.
    Ken, We have two older Miller welders at work. I look them every day,and you know I can't positively say,but I think the one I used was called a DeltaWeld 651 with .045 Flux Core wire. Is that what you were asking?
    Greg
  7. #6
    Join Date
    Jul 2003
    Posts
    11,125
    Westminster, MD
    John Deere 4110
    Quote Originally Posted by glc24 View Post
    Thanks guys
    Greg
    Yeah, that is what I was asking...
    John Deere 4110HST
  8. #7
    Join Date
    Jul 2003
    Posts
    1,993
    MN
    Ford 960, 7700, TW20, 1720; IHC H, 300; Ollie S77
    Holy buckets! That's built stout.
    I made one, from a $75 carry all frame, and a $15 roack box I bought at a farm auction. I didn't want to go over $100 so I didn't paint it, the original red on the carryall, the creame on the rock box. I think you have more invested in paint than I do in my whole rig.
    Wow, well you shouldn't have to worry about denting it.
    What I miss most with something hanging on the 3pt is - a hitch. If you were to bolt or weld a 2" reciever on the bottom of it somehow, so it didn't stick out in the way.....
    --->Paul
  9. #8
    New Member
    Join Date
    Jul 2009
    Posts
    12
    I'm just wondering why so thick on the wall steel?
  10. #9
    Veteran Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    1,050
    Flushing, Michigan
    Kubota B2620
    Wow, very nice job on the box. Way heavier than I would need.
    I agree a 2 inch receiver hitch incorporated somewhere would be useful.
    I do think you over did it on the plate, if you are going to fill it with material for weight, seems like it could have been 3/16", but like Rambler said, you don't have to worry about denting it.
    That should last 2 or 3 lifetimes.
  11. #10
    Join Date
    Dec 2009
    Posts
    848
    Southwestern, Pa.
    As I stated in my original post,the 1/2" plate is the only material I was allowed to take. IT WAS FREE!
    Greg
Similar Threads
  1. The latest on "J2D2" Ballast box design
    By Dan22 in forum Build-It Yourself
    Last Post: 03-22-2009, 01:31 PM
  2. Ballast 3-Pt hitch does not lower Ballast Box all the way
    By splotkin in forum Kubota Owning/Operating
    Last Post: 10-27-2008, 07:47 AM
  3. FEL, CUT and ballast box
    By 4runner in forum Buying/Pricing/Comparisons
    Last Post: 10-12-2008, 07:46 AM
  4. Ballast Pix of concrete filled ballast box
    By JB4310 in forum John Deere Owning/Operating
    Last Post: 11-16-2007, 11:13 AM
  5. Ballast Ballast Box weight for a L2800
    By MichaelME in forum Kubota Owning/Operating
    Last Post: 09-08-2007, 05:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
