bcarwell
Gold Member
Hi folks, I was wondering with a little adapting if a cheapo HF shop press might do double duty as an "in a pinch" log splitter. I have never seen the specs on the movement rates of the cylinders and suspect that is the real issue, but maybe if you are doing more than 5 -10 logs for a weekend. And I suppose there is a safety issue with there being no lateral support for the log (although I suppose you could put the log horizontally). Obviously due to the "shop" location of the press, not an ideal place to be splitting wood. But I hate to invest in a dedicated log splitter when, here in Central Texas although we have Blazing Saddles we generally don't have much need for blazing fires other than for cosmetic purposes. So I go through enough wood to make it a hassle to do manually but not enough to justify a wood splitter other than my son. My shop press would be in my outside shop so messing up an already messy shop is not an issue.
Anyway, just a thought. The HF 6 to 20 ton splitters are very, very cheap relative to conventional log splitters...
Bob
Bob
