HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
LinkBack Thread Tools Display Modes
Old 08-03-2002, 10:31 PM   #1 (permalink)
Default calling wroughtn harv
OK Harv or anybody else, have you ever made any brackets to attach on homemade implements to fit on a standard bobcat style quick attach loader like in the picture?
kcbarnes is offline   Reply With Quote
Old 08-04-2002, 08:11 AM   #2 (permalink)
Elite Member
Default Re: calling wroughtn harv
Yup! doing two today as a matter of fact. I just copied the pattern on the bucket and it's nothing but a thing.
I'm making a couple of buckets for hauling concrete. One for an order and another as a spec for a potential order. It's almost as easy to do two at the same time as it is to do one.
The angle is about thirty degrees as I recall. I've got a pattern for it at the shop.
I have found out that even though the top groove is the same in all the quick attaches I've found so far. There is a difference in the spacing of the bottom keeper holes between the brands, Case, Bobcat, JCB, etc.
I'm building concrete buckets. Something I just did when making mine turns out to be something evidently some other folks who make them didn't do. I allowed for the concrete to be as close to the tractor as possible. The closer it is to the tractor the more leverage the tractor has for safely hauling it. I also put on a splash lip. Some of the others out there don't.
Once you start making your own tools for your tractor you might notice which of the hydraulic controls are easiest to use and give you the most confidence. Then use that information when designing your tool.
Let's say you're wanting a cherry picker boom for lifting and moving things. You've noticed your bucket tilt is not as comfortable for you for lifting as is the bucket lift function. If you're lifting things high like to place them in a loft or on a truck. You might consider changing the angle of your boom in relationship to the attach plate to take advantage of this.
If your boom was to go out straight from the plate when you want to go higher after you reach your maximum boom lift. You'd have to use your tilt function. But if you make the angle up from the get go then you can still use your lift function when you need the most control.
I hope I made some sense.
It's sorta like the design of the concrete bucket. When I made the bulk of the void as close to the attach plate as possible I gave the tractor the ability to carry more safer. If I had done like some of the others the weight would be out farther which drastically cuts down on capacity and comfort of use for the operator. When that pucker string is stretched very few of us are really comfortable over any length of time.
wroughtn_harv is offline   Reply With Quote
Old 08-04-2002, 09:29 AM   #3 (permalink)
If you get a chance, could you post a pic of your brackets?
Old 08-05-2002, 06:59 AM   #4 (permalink)
Elite Member
Morning,
<font color=blue>If you get a chance, could you post a pic of your brackets?</font color=blue>
Here's a picture of the old concrete bucket and the backhoe attachment. As you can see I just happened to use whatever was handy at the moment, catch as catch can you might say.
Old 08-05-2002, 07:06 AM   #5 (permalink)
Elite Member
Here's a picture of a new concrete bucket in the flat mode. You have to absolutely love plasma torches.
Old 08-05-2002, 07:08 AM   #6 (permalink)
Elite Member
Here it is in 3D.
Old 08-05-2002, 04:29 PM   #7 (permalink)
My heros used to be cowboys,now your it.Thanks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
