ihuntbear
Gold Member
- Joined
- Jan 19, 2010
- Messages
- 422
- Location
- new brunswick, canada
- Tractor
- 2015 tym T554 and 1999 Kobota m4700
for those of you that built your own grapple.what size steel did you use for the bottom forks and the top forks.I went to the steel shop today all they have is mild steel.They said I should go with 1/2 x 4" flat bar so it wouldn't bend when in use.also what size for tubing going across the back where it hooks up to the fel.I did a search on this all I found was a drawing on how to make it but couldn't find anything on the size of steel was used.it would be great if somebody had a drawing with all the sizes and spacing.I am looking at building a 48" to 60 " one for quick coupling.
