A simple three point counterweight
   / A simple three point counterweight #11
Yeah...That blue color does make it look heavy. How does that work anyway :confused2: ?
larry
   / A simple three point counterweight #12
Youll find that concrete weighs 3800-4000 pounds per cu yd -- about 19.9#/gal. I dont know how a 55 drum could be under 1k unless it wasnt full.
larry
Assuming 55 gal drum, this converts to 7.3524 cubic feet times 150lbs cu/ft (concrete) equals 1102.86 lbs if it is level to the top.
Steve
Mine weighs about 800lbs
   / A simple three point counterweight #13
I cut an old steel drum in two halves. Inserted two #5 rebars and filled the halves with concrete leftover from pouring some piers. I hang them from the 3-point after retracting the drawbar. I weighed the 1/2 drums and each one weighs 590 lbs. Usually I use just one, but I could stack them on my heavy duty 3-pt carrier if I needed 1180# of counterweight.
Steve
Sharp looking counterweight. Good job!
   / A simple three point counterweight #15
Beauty is in the eye of the beholder but why would someone consider hanging an ugly old barrel an a nice looking tractor? :cool:
But if I was going to build a barrel weight, I would consider a cat. 1 draw-bar and poke that through the barrel, and fill with cement. This would be stronger than re-bar as far as bending, and they only cost $20 or so.
Be careful so you don't make the thing to heavy for your tractor. There will be a lot of jerking around back there and you don't want to rip something off the rear end. I never heard of that happening, but I'm new here.
:thumbsup:
   / A simple three point counterweight #16
:thumbsup:
I made one like this using a cat 1 draw bar and it worked great until I managed to tip it over and it snapped off one of the pins on the draw bar. :mad:
Now it's a useless giant paperweight cause I can't get the old draw bar out of it to replace it.
I think I'd rather have had it bend so I could just bend it back again.
   / A simple three point counterweight #17
Sounds like a good reason to buy a welder!
   / A simple three point counterweight #18
I made a square box and used some Cat 1 pins instead of a draw-bar and it works fair. They stick in the concrete about 4" or so so I welded a bar to each on the inside of the tank so they wouldn't pull out.
I put a hitch on the back of the BB and was pulling and jerking so much pulling trees down that I bent them on maybe a 20 deg angle. They still work and hook up OK but I am gun-shy about hammering on them to straiten them out. :confused2:
If I crank on them to much, i would end up with a very pretty paper weight to.
   / A simple three point counterweight #19
Here is mine, about 750 lbs with a 2 inch receiver in the back, and 2 inch PVC tubes cast in the concrete for handle tools. and lots of room for chains and other things in the top.
James K0UA
   / A simple three point counterweight #20
James K0UA
Got more photos??? Interested in how you did the Toplink... I'm going back and forth from 55 gal. drum to a loaded pallet.
