LD1
Epic Contributor
I had a new member on here stumble onto one of my pics of the lawn roller we made in the "show off your mig projects thread" and he PM'd me wanting some more info. So instead of PMing or e-mailing him I tought I would share it with the rest of TBN. As with most of our projects we took step by step photos along the way.
Just some details, The roller is 38" in diameter and 48" wide. The reason for these dimensions are that is what a rolled sheet of 4' x 10' steel comes out to be. However, we had to have it sheered into 2-2ft by 10ft peices because the local sheetmetal shop could only roll upto 3'.
The body is 11ga, which is 1/8" steel. The end caps and the center peice is 1/4". Dry weight is about 600lbs and it can hold about 230 gal of water. Which is 1800lbs. Total weight can be up to 2400lbs.
