Water Trailer Build
   / Water Trailer Build #1
coreshot
Gold Member
Utah
Kubota BX24
I'm building a small trailer to tow behind the Kubota. It will have a 125 gallon water tank on it. I currently have no well at the cabin, so I need a way to haul water from my brother's place to mine. I figure in the future when I do have my well in, it will be handy to haul water to other parts of my 6.23 acres when I need it.
I have a bunch of scrap metal on hand, so I'm going to see how cheaply I can do this build. The frame is built out of some 3 inch c-channel I had. I had to purchase the d-rings, and the suspension set, so far I'm just over $100 in.
Pics so far...I know the welding's not the purdiest, but I'm trying...
   / Water Trailer Build #2
I'm looking forward to seeing this build happen.
Are you planning on getting the water out by gravity feed, or are you going to have some kind of pump?
Cory, with that frame you shouldn't have any problems hauling that 1000 lbs of water! :thumbsup:
Yeah it's a little overkill, but free's free!:cool:
For the time being, it will be gravity feed. Depending on what I do with it later, it may need a pump. Generally I will just be filling 5 gallon jugs off it.
setting up the springs...
Looks good! I didn't mean to imply it was over kill just heavy enough.
When I first read your post, I thought it said 1000 gallons. :laughing:....oh well, it is overkill for what it needs to be.
   / Water Trailer Build #9
For hauling water, overkill is good.:thumbsup:
A couple pics of the tongue...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A52748)
PENDING SELLER...
Skid steer auger plate (A50322)
Skid steer auger...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2018 KENWORTH T680...
2014 AMADAS SPC-6-36 LOT NUMBER 211 (A53084)
2014 AMADAS...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
