Snowblower plans?
   / Snowblower plans? #1
jimgerken
Minnesota
John Deere 3720
I am considering building my own snowblower. Anyone been through this, have any plans, internet sites, photos, advice , etc?
   / Snowblower plans? #2
I have talked to a couple of guys around here lately that have bought some old used up hydrostatic drive combines and are in the process of converting them to snowblowers. Haven't seen anything running but sounds like a feasible project. With hydro drive you could maintain full engine power and RPM while having infinite speed control- sounds good to me! If I hear any more, or see something; will post it.
   / Snowblower plans?
Thanks for the reply! That would be interesting since there are many old combines setting around for scrap price, keep us posted , with photos if you get the chance.
In my original post I should have been more clear and said I wish to make my own snowblower ATTACHMENT for a compact tractor. Sorry about that. Anybody tried such a thing? I have a smaller one (single stage 36") to basically copy and scale up to 50", but am still looking to expand my ideas and understanding before starting. Thanks again guys. And yes, there will be lots of pics posted once I get rolling.
   / Snowblower plans? #4
I would think this is a major project. How long do you think it will take you to get it done?
   / Snowblower plans? #5
Don't know what you have that you are thinking of copying but we had a home made blower when I was a kid that worked really well, and we got a lot of snow there. It was a so-called V-type, where the tractor drives through the snow frontwards and pulls the blower. Are you familiar with these? In some areas they were made commercially. Rather than an auger the pto spins kind of a fan or paddle type blade.
I have one of these now and it works not too badly, but in wet stuff it can clog up a bit. The one we had before didn't have any fancy curved sides and it didn't clog up so much. The curved sides work well in powder though.
Jim
   / Snowblower plans?
"time to get it done?" Well, Ive given it a little thought and I believe I can get it to the test phase in about 16 working days. After test, if everything works well, I would dissmantle it and have it sand blasted in prep for paint. I have a plan to use some preformed sheet steel parts to save alittle hassle. For instance, I am searching for a 30 pound LP cylinder, which is 15" diameter and about four feet tall. From this I can torch out 2 pcs of housing so I won't have to have anything rolled. I did find a nice helical gear right-angle box at Surplus Center, good for high speed use, for about $90. It will run 2000 RPM, and transfer my tractor's 17PTO HP, to the cross-shaft. The Cross shaft is going to use a Lovejoy coupling on the gearbox end, and then it will be 2 feet long to reach the one side of the blower housing, where the chain reduction (2:1 reduction) will carry the power to the rotor. This last part is just like most single-stage blowers you see, but of course they are belt driven typically, so they don't have a right-angle drive box. The rotor will turn on 1.25" shaft, welded into a 3 or 4" tube center for the flighting, depending on whats available. I have not purchased anything yet, as I thought as I got closer to starting, I'd total it all up and make sure I was saving a thousand over purchasing JD new. If no big savings, there will be no project. Later this week I will try to get over to the metal recycling center to see what jewels I can find for this and a couple other projects I have in mind.
Will keep you all posted....
   / Snowblower plans?
Jim w: Thanks for the input. Yup, I'd seen this type before, my neighbor has one. Looks like a good system, simple and cheap to produce. I have decided on a front-mounted unit however. It comes down to: 1) want to have it out front for visibility and control, if possible 2) already own the JD quick-tach system for front-end 2000RPM power and lift for implements and am using the 51" brush, the blower will be made to fit the quick-tach, so changing from blower to brush will take under a minute 3) putting blower on front leaves back free for box blade for weight and additional removal capability, like ice ridges. I guess it would be a rear mount project if it were not for the quick-tach deal. It is nicest to have your implement in front of you when possible, so this should be the best setup. And the plan is to build a single-stage machine, the kind that use an auger-rotor spinning at about 1000RPM, which carries the snow to the center and also blows it up the chute. In my experience, these do not ever plug, are the most tolerant of gravel (my driveway is and always will be gravel), and wear out very slowly. So those are my plans so far. Thanks again for the input.
   / Snowblower plans?
Went to the industrial junkyard two days ago. Found some great stuff. I found some stock that had been rolled to make cement truck chute extensions. It's 0.100" thick, formed into a 16" diameter half-cylinder, and unfortunately it is only 47" long so I bought two and will have to splice. Also, found a splined PTO shaft with u-joint bearings, all new unused and rusty, for $15. All it needs is the ends, 1" shaft on the gearbox end, and 1" 15 splines on the tractor end. Also bought some 4" tube. This week I will be ordering flighting and gearbox. Once most of the raw materials are in, I will post a photo. I am trying to figure out how to post a diagram, sort of a plan, of what I'm going to build. So far, the plan only exists on paper, hand-drawn.
   / Snowblower plans?
I have now received the flighting, the gearbox, the grader blade, a Lovejoy coupling, and a few other pcs. Last weekend I started dismantling another old project that had outlived its usefullness and from that I have salvaged some #50 roller chain sprockets, some 1" shaft and 1" cast pillow block ball bearings. I am missing some 8" tube like silo-filling blower pipe, which will be used for the outlet/spout. I am still undecided about how to turn the chute. I would like to use a hydraulic motor, but it would have to be a slow-speed one, and I think the cost is too extravegant. I may use an automotive electric window motor/gearbox, as these are almost free. No construction has started yet, as other things are "in the way". Hopefully I will begin two weekends from now. Pictures will follow...
   / Snowblower plans?
Made a little headway, but still battling to get the snowblower to the top of the list. Here's a shot of a couple pcs of metal, one for the main housing and a smaller pc for the chute, nothing is welded yet.
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A55851)
2015 Toro Multi...
John Deere 3032E with loader and Box Blade (A55314)
John Deere 3032E...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
(1) 14in Trailer Wheel and Tire (A54865)
(1) 14in Trailer...
