powerstroke444e
I am building a sickle bar mower that I can pull behind my ATV. Reason being I can't get the kubota zero turn on the slopes or close enough with out geting stuck or going swiming.
I started with a sickle bar mower that was mounted on old AgCo lawn mower 48". Made a pin hitch attachment that has own engine atv tires torsion axles and winch to raise and lower the bar.
I will post photo's of the build as it 90% done but I am trying to figure out the clutch. I have a 6hp Kohler with 3/4" shaft and I am thinking of adding a go-cart clutch, to control the engage the mower. Any reason that won't work?
I will get photo's up tommorow.
