Runner
- Joined
- May 12, 2007
- Messages
- 1,716
- Location
- Missouri
- Tractor
- John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
Finally got around to building an adapter to use my quick attach pallet forks on the three-point hitch.
Used (2) 17 inch long pieces of 10 inch wide channel iron for the main attachment points. Bridged between them with 2x2x1/4 tube and 3x3 angle. Tabs for the pin connections were made from 2 inch by 3/8 inch bar stock.
The attachment point for the top hooks was made using 1 1/4 inch round stock.
I knew I had a weak spot in the top link attachment with the angle iron, so I tried to "box" it in by welding in a piece of 1/8 inch thick sheet steel, but it wasn't enough. If you look closely at the top angle in the "load test" picture, you can see it bowing.
So, I added a 2x2 angle for reinforcing in back of the 3x3 angle. Haven't had a chance to re-test it yet, but I feel that this will do the trick....
I think the "test rock" must weigh in at around 800 lbs or so, because I could just barely lift it a foot or so with the forks on the loader.
Incidentally, A BIG THANKS to you guys who suggested using bi-metal hole saws for this stuff in the recent "hole-making" thread. I used Lennox hole saws for all the holes and they worked beautifully. I feel really stupid for not trying them sooner...
